Supported acquisition devices
Integrated drivers
The following drivers have been integrated into OpenViBE release 0.15.0.
Manufacturer Amplifier Driver Name OS Status Officially Supported
ANT Neuro ASALAB EEG / ERP amplifier Either MindMedia Nexus32B or TMSi drivers Has been reported to work No
Others TMSi derived devices Either MindMedia Nexus32B or TMSi drivers Untested No
BrainMaster Atlantis Brainmaster Atlantis and Discovery Stable Community :
  • Mensia Technologies
Discovery Brainmaster Atlantis and Discovery Stable Community :
Brain Products V-Amp Brain Products V-Amp Stable No
actiCHamp Brain Products actiCHamp Stable Yes, contact Mensia Technologies
QuickAmp Either MindMedia Nexus32B or TMSi drivers Has been reported to work No
BrainAmp Series Brain Products BrainAmp Series Stable Community :
  • Yann Renard
All Brain Products BrainAmp Standard (through BrainVision Recorder) Stable Community :
  • Emmanuel Maby (INSERM)
  • Pierre-Emmanuel Aguera (INSERM)
CTF/VSM MEG CTF/VSM MEG Unstable Community :
EGI Net Amps 300 EGI Net Amps 300 (through AmpServer) Unstable Community
Emotiv EPOC Emotiv EPOC Stable Yes
gTec gUSBamp g.Tec gUSBamp Stable(multi amp missing) Yes
gMobilab+ gTec gMOBIlab+ Stable Community :
  • Lucie Daubigney (Supelec)
Micromed SD LTM Micromed SD LTM (through SystemPlus Evolution) Stable Yes
MindMedia NeXus32 MindMedia Nexus32B Stable Yes
Neurosky Mindset NeuroSky MindSet
(MindWave Mobile since SVN r3590 / unreleased 0.16.0)
Stable Yes
OpenEEG MonolithEEG OpenEEG Modular EEG P2 Stable Community :
  • Christoph Veigl (University of Applied Sciences Technikum Wien)
  • Yann Renard
ModularEEG OpenEEG Modular EEG P2 Stable Community :
  • Yann Renard
TMSi Porti32 Either MindMedia Nexus32B or TMSi drivers Stable Yes
Refa32 Either MindMedia Nexus32B or TMSi drivers Stable No
Others devices Either MindMedia Nexus32B or TMSi drivers Untested No
Beta drivers
These drivers are currently being integrated or does not comply with, some of them can be found in the current Acquisition Server branches in the SVN, others can be found in the deprecated branches folder (checkout the SVN at address svn://scm.gforge.inria.fr/svn/openvibe/deprecated-branches). To use them, you must build the corresponding branch. If the driver is in a deprecated folder, you first have to put it manually in your SVN local repository under openvibe-application/acquisition-server/branches/.
Manufacturer Amplifier Driver Name OS Status Officially supported
Mitsar EEG 202 Mitsar EEG 202 Unstable Community :
  • Guillaume Lio (GipsaLab)
Neuroscan SynAmps2 Neuroscan SynAmps2 (through Scan 4.3) Unstable Community :
  • David White (Swinburne University of Technology)
This driver has been moved to the deprecated branches SVN folder
(openvibe-applications-acquisition-server-wip-neuroscan)
This entry was posted in Features and tagged . Bookmark the permalink.
