- NB: Document based on OpenViBE 0.8.0 (30-sept-2010).
Introduction
This page is intended to driver developers and shows how to create a new acquisition driver for the OpenViBE acquisition server. The driver is a single object that interacts with the hardware acquisition peripheral and formats acquired measures and information in a way the acquisition server understands. Once the acquisition server receives measures and information, it is able to send them to the multiple connected clients.
The connection between the hardware and the driver does not really matters to the acquisition server. Some hardware manufacturer will provide an API so that the driver has direct access to the peripheral through physical connection (maybe USB, serial port or so). Some will provide a proprietary acquisition server, which allows connections through TCP/IP to stream the measures in real time. Whatever your hardware manufacturer provides, the OpenViBE driver is in charge of collecting a set of information / measures and to format all of them according to the format of OpenViBE.
How is the driver used ?
First, the driver has to give a name to the acquisition server. This will be used in the acquisition server GUI to easily identify the hardware the user is working with. This is why you should give a precise name to the driver, using for example, the hardware manufacturer name and the hardware model name.
The driver essentially deals with two kinds of data :
- the header
- the buffer
The header is the part of data that does not change along time, containing several identifiers about the experiment being done, information about the channels being acquired and so on. See OpenViBEAcquisitionServer::IHeader for more details about this header.
The buffer is the part of data that changes along time. It contains the different samples for each channel on a given time period which depend on the number of samples per sent channel. This value is given to the driver during the initialization phase.
To deal with these data, the driver is used by the acquisition server at different stages of the execution. The three most important are :
- configuration
- intialization / uninitialization
- acquisition
The configuration stage can be used by the driver to request the header’s information that won’t be available from the hardware. Depending on the hardware, all the information for the header may be found in the streamed data, resulting in an non-configurable driver (may be easier for the acquisition server user). For example, a driver with physical connection may not provide subject age or gender. Such a driver will need a configuration phase before it can be used.
In the intialization stage, the driver requests readyness status to the hardware. Once the driver is initialized (this means OpenViBEAcquisitionServer::IDriver::initialize returns), the driver should have a complete header ready to be sent to the acquisition server. The driver’s OpenViBEAcquisitionServer::IDriver::loop is regularly called so that the driver may be able to keep the connection to the device alive, dropping some data if needed.
The acquisition stage comes when OpenViBEAcquisitionServer::IDriver::start is called. From this stage, the driver is regularly requested to provide new data within the OpenViBEAcquisitionServer::IDriver::loop function.
A schematic representation of the automate for a driver is here below :
Now that you know what a driver is, we shall start coding it. We provide a developer tool named Skeleton-generator, that generates for you all the files you will need to build the driver.
Using the Skeleton-Generator
The Skeleton-generator needs the following information :
- Author name
- Company/Affiliation
- Driver name
- Class name
- Min & Max channel count
- Sampling frequencies
- Directory where the files will be generated
And will generates the following files :
- the driver class code (.h and .cpp)
- the configuration class code (.h and .cpp)
- the GtkBuilder interface file (.ui)
- a readme.txt file that explains how to use the generated files.
Each field has its own conditions, use the “Help” buttons for detailed examples. Once all fields are filled, you must check it by pressing the dedicated button. A report will be displayed, asking you to modify the wrong fields if any. If everything is good, you can press the button “Generate!” to generate the files. Let’s take a closer look at the skeletons now.
Coding the driver
Coding the driver consists in implementing an OpenViBEAcquisitionServer::IDriver object.
Here comes the driver skeleton generated.
The header
The header would look like this :
#include "../ovasIDriver.h"
#include "../ovasCHeader.h"
#include <openvibe/ov_all.h>
namespace OpenViBEAcquisitionServer
class CDriverTestSkGenerator : public OpenViBEAcquisitionServer::IDriver
public:
CDriverTestSkGenerator(OpenViBEAcquisitionServer
::IDriverContext& rDriverContext);
virtual ~CDriverTestSkGenerator(void);
virtual const char* getName(void);
virtual OpenViBE::boolean initialize(
const OpenViBE::uint32 ui32SampleCountPerSentBlock,
OpenViBEAcquisitionServer::IDriverCallback& rCallback);
virtual OpenViBE::boolean uninitialize(void);
virtual OpenViBE::boolean start(void);
virtual OpenViBE::boolean stop(void);
virtual OpenViBE::boolean loop(void);
virtual OpenViBE::boolean isConfigurable(void);
virtual OpenViBE::boolean configure(void);
virtual const OpenViBEAcquisitionServer::IHeader* getHeader(void)
return &m_oHeader;
virtual OpenViBE::boolean isFlagSet(
const OpenViBEAcquisitionServer::EDriverFlag eFlag) const
return eFlag==DriverFlag_IsUnstable;
protected:
OpenViBEAcquisitionServer::IDriverCallback* m_pCallback;
// Replace this generic Header with any specific
// header you might have written
OpenViBEAcquisitionServer::CHeader m_oHeader;
OpenViBE::uint32 m_ui32SampleCountPerSentBlock;
OpenViBE::float32* m_pSample;
private:
* Insert here all specific attributes, such as USB port
* number or device ID.
* Example :
// OpenViBE::uint32 m_ui32USBPort;
We will now describe in details the implementation of these functions. The implementation can be divided in 3 phases : the preliminary, the configuration, the acquisition.
Preliminary
The first part of the cpp file contains the constructor, the destructor and the getName function. The code is relatively simple and speaks for itself.
CDriverTestSkGenerator::CDriverTestSkGenerator(IDriverContext& rDriverContext)
:IDriver(rDriverContext)
,m_pCallback(NULL)
,m_ui32SampleCountPerSentBlock(0)
,m_pSample(NULL)
m_oHeader.setSamplingFrequency(128);
m_oHeader.setChannelCount(4);
CDriverTestSkGenerator::~CDriverTestSkGenerator(void)
const char* CDriverTestSkGenerator::getName(void)
return "Simple test driver (p1)";
Configuration
The configuration phase calls the dedicated GUI. The CConfiguration object fills the header with information from the GUI : subject identifier, number of channel, channel names, sampling frequency etc.
boolean CDriverTestSkGenerator::isConfigurable(void)
return true; // change to false if your device is not configurable
boolean CDriverTestSkGenerator::configure(void)
CConfigurationTestSkGenerator m_oConfiguration(m_rDriverContext,
"../share/openvibe-applications/acquisition-server/interface-TestSkGenerator.ui");
if(!m_oConfiguration.configure(m_oHeader))
return false;
return true;
Acquisition
To acquire the data, we must firstly initialize the driver. The initialize function will be called by the acquisition server with a given callback, to be feeded with samples. If the hardware needs initialization, put the dedicated code in this function. The uninitialize function desallocate properly everything.
boolean CDriverTestSkGenerator::initialize(
const uint32 ui32SampleCountPerSentBlock,
if(m_rDriverContext.isConnected()) return false;
if(!m_oHeader.isChannelCountSet()
||!m_oHeader.isSamplingFrequencySet()) return false;
// Builds up a buffer to store
// acquired samples. This buffer
// will be sent to the acquisition
// server later...
m_pSample=new float32[m_oHeader.getChannelCount()
*ui32SampleCountPerSentBlock];
if(!m_pSample)
delete [] m_pSample;
m_pSample=NULL;
return false;
// initialize hardware and get
// available header information
// from it
// Saves parameters
m_pCallback=&rCallback;
m_ui32SampleCountPerSentBlock=ui32SampleCountPerSentBlock;
return true;
boolean CDriverTestSkGenerator::uninitialize(void)
if(!m_rDriverContext.isConnected()) return false;
if(m_rDriverContext.isStarted()) return false;
// uninitialize hardware here
m_pSample=NULL;
m_pCallback=NULL;
return true;
Once the driver is initialized, the acquisition can start. The start and stop functions handle the connection and ask the hardware to start/stop sending the EEG data.
boolean CDriverTestSkGenerator::start(void)
// request hardware to start
// sending data
return true;
boolean CDriverTestSkGenerator::stop(void)
if(!m_rDriverContext.isStarted()) return false;
// request the hardware to stop
// sending data
return true;
Finally, the loop function reads the data and stores it in a buffer. This function is called as fast as possible by the acquisition server once the driver is connected (intialized).
boolean CDriverTestSkGenerator::loop(void)
if(!m_rDriverContext.isStarted()) return true;
OpenViBE::CStimulationSet l_oStimulationSet;
// receive samples from hardware
// put them the correct way in the sample array
// whether the buffer is full, send it to the acquisition server
m_pCallback->setSamples(m_pSample);
// receive events from hardware
// and put them the correct way in a CStimulationSet object
m_pCallback->setStimulationSet(l_oStimulationSet);
return true;
For a simple working example of driver, please take a look to the generic oscillator. This driver does not connect to any hardware. Instead, it produces the samples itself using sinusoidal signal. This can easily be tuned to match your needs for any specific driver and also could be used to test your OpenViBE platform.
Using the driver
When you have a working driver you probably want to test / use it. In order to achieve this task, you have to register the driver to the acquisition server. Put your .h / .cpp files in the acquisition server project : openvibe-applications/acquisition-server/trunc/src/your-driver-name Then edit the main acquisition server file ovasCAcquisitionServerGUI.cpp and add your driver in the driver list.
#include "your-driver-name/ovasCDriverYourDriverName.h"
CAcquisitionServer::CAcquisitionServer(const OpenViBE::Kernel::IKernelContext& rKernelContext)
m_vDriver.push_back(new CDriverYourDriverName(m_pAcquisitionServer->getDriverContext()));
If you used the skeleton-generator, please look at the readme file for further details.
Advanced developments
Your driver may be functionnal, but not complete. You should be able to connect it and start it in the Acquisition Server, however more developments are possible to improve your driver. The following tutotials will help you with more advanced developments:
- Tutorial: configuring a new driver : how to set up a dedicated GUI so the user can configure the driver.
- Tutorial: Using the built-in Impedance Checker : how to use the given impedance checker mechanism, if your device is capable of.
- Tutorial: Jitter monitoring and drift correction : the acquisition is somehow drifting from its theorical sampling rate ? Correct it with jitter monitoring and drift correction.
Support
In case you have problem in developing the driver, feel free to contact experienced OpenViBE developers on the forums or IRC channels.
Enjoy OpenViBE !
