Hello all.
I work in the field of Motor Imagery (MI) for left and right hand movement.
So far I have managed to get results with success rates of 66% with classical algorithms CSP and LDA.
I think it's time to move on to something more specialized by including python scripting boxes into my scenarios.
Are there such examples that I could find online?
Has anyone done something similar with better results than mine that could help or give advice? if so i would appreciate it very much.
Please let me know.
Motor Imagery (MI) and Python scripting
Re: Motor Imagery (MI) and Python scripting
Hi,
Last Time I say that to you : don't send private message in addition of your posted message, I have enough spam without that. I answer whenever I come and I come often. Next time I don't answer.
For your question, I have implement Matrix classifier with riemmannian metric. and In pythom, there is a new box which use scikit learn., With box tutorials example you have some scenarios to see how to use it.
Thibaut
Thibaut
Apologies for that. I don't remember you telling me not to send private messages and isn't spam messages. You probably told someone else.
I am sending private messages only if pass a couple of days without answer so if this is a problem I will never send you a private message again.
Nonetheless, thanks for your answer:
Please let me know and apologies again for the messages issue.
Am not sure if I understand right. Where can I find this Matrix classifier with riemmannian metric in python and who is this new box scikit learn. Where is this box tutorials.For your question, I have implement Matrix classifier with riemmannian metric. and In pythom, there is a new box which use scikit learn., With box tutorials example you have some scenarios to see how to use it.
Hi,
The box-tutorials is with other. When you open a scenario with no scenario open (or an unsaved scenario) it push you directly on box-tutorials and bci-example folder.
I misspoke, the matrix classifier boxes are separate from the python boxes.
Python boxes with scikit learn are in scripting / pybox
Classifier them riemannien in riemannian geometry
Thibaut
Thibaut
