The Emotiv EPOC has 14 channels, and you theorically cannot move them on different positions.
When I developed the driver, I took the 10-20 position labels given by the manufacturer as my channel names.
Doing so I removed the possibility to rename channels... Same goes for the channel count you cannot change in the driver properties (14 no matter what).
I still kept the "rename channel" button in the GUI; that's a mistake regarding what I wanted to do.
If you need to rename the channel, I assume you changed the positions, or you need another naming convention...
In these cases I suggest you use the
Channel Rename box for that purpose, directly after the Acquisition Client box. You specify in this box the channel list with semi-colum separator (e.g.
C1;C2;C3;C4)
The new channel names can of course be saved in the box settings (you can save these settings to export them using the "usual"
setting files).
To answer the underlining question about renaming the channels in the acquisition server and saving these names, I updated the
Acquisition server documentation section.
To save the names you need to:
- Click on "rename channels" button
- select a name for each channel index
Then you can:
- save the names in a file. The file produced is simple text, one name per line. For example:
Hope this helps !
