A problem with creating a driver
Posted: Tue Jul 15, 2014 8:19 am
Hi,
I am a beginner to openvibe software, I work on a BCI project. I have made a 2 channels EEG system and I want to use openvibe software to acquire and process my EEG data. I have to create a driver due to this ink:
http://openvibe.inria.fr/tutorial-creat ... on-server/
I generate files from skeleton generator, due to READ ME file:
The Configuration and Driver classes:
- ovasCConfigurationTestDriver.h
- ovasCConfigurationTestDriver.cpp
- ovasCDriverTestDriver.h
- ovasCDriverTestDriver.cpp
You can put these files here in your local repository:
[openvibe-repository]/contrib/plugins/server-drivers/[my-device]/src/
The glade interface:
- interface-TestDriver.glade
You can put this file in here in your local repository:
[openvibe-repository]/contrib/plugins/server-drivers/[my-device]/share/
Don't forget to declare your driver to the Acquisition Server application.
This happens in ./contrib/common/contribAcquisitionServer.inl, there you
will find examples of such declarations.
Now, there is not my created driver’s name in driver list of openvibe acquisition server, so I don’t know if my driver is registered to the acquisition server or not? And how should I work with this new driver?
Thank you in advanced for any help.
Best Regards
Best Regards
