Stimulation Codes for Motor Imagery
Posted: Tue Jul 31, 2018 2:44 am
Hello,
I am conducting analysis using the motor imagery data. I see the list of stimulation codes (http://openvibe.inria.fr/stimulation-codes/) however these do not correlate to the numbers in the dataset.
For example I'm seeing decimal numbers such as 1009, 9000, 785, 9001, 768, 769, 781, 800, etc. When I convert these to hexadecimal I am not seeing those hex values on the list of stimulation codes. Please let me know if there is anything I am overlooking, I appreciate your help!
Thank You!
Thank You!
