Stimulation codes
  • NB: last update for OpenViBE 0.5.0 (18-feb-2010).
The stimulation codes are encoded on 64 bits unsigned integers.
Here is a complete list of all stimulations in OpenViBE, values and constant names.
OpenViBE stimulation codes
#define OVTK_StimulationId_ExperimentStart                   0x00008001 // 32769
#define OVTK_StimulationId_ExperimentStop                    0x00008002 // 32770
#define OVTK_StimulationId_SegmentStart                      0x00008003 // 32771
#define OVTK_StimulationId_SegmentStop                       0x00008004 // 32772
#define OVTK_StimulationId_TrialStart                        0x00008005 // 32773
#define OVTK_StimulationId_TrialStop                         0x00008006 // 32774
#define OVTK_StimulationId_BaselineStart                     0x00008007 // 32775
#define OVTK_StimulationId_BaselineStop                      0x00008008 // 32776
#define OVTK_StimulationId_RestStart                         0x00008009 // 32777
#define OVTK_StimulationId_RestStop                          0x0000800a // 32778
#define OVTK_StimulationId_VisualStimulationStart            0x0000800b // 32779
#define OVTK_StimulationId_VisualStimulationStop             0x0000800c // 32780
#define OVTK_StimulationId_VisualSteadyStateStimulationStart 0x00008010 // 32784
#define OVTK_StimulationId_VisualSteadyStateStimulationStop  0x00008011 // 32785
#define OVTK_StimulationId_Label(i)                          0x00008100|((i)&0xff)
#define OVTK_StimulationId_LabelStart                        0x00008100 // 33024
#define OVTK_StimulationId_Label_00                          0x00008100 // 33024
#define OVTK_StimulationId_Label_01                          0x00008101 // 33025
#define OVTK_StimulationId_Label_02                          0x00008102 // 33026
#define OVTK_StimulationId_Label_03                          0x00008103 // 33027
#define OVTK_StimulationId_Label_04                          0x00008104 // 33028
#define OVTK_StimulationId_Label_05                          0x00008105 // 33029
#define OVTK_StimulationId_Label_06                          0x00008106 // 33030
#define OVTK_StimulationId_Label_07                          0x00008107 // 33031
#define OVTK_StimulationId_Label_08                          0x00008108 // 33032
#define OVTK_StimulationId_Label_09                          0x00008109 // 33033
#define OVTK_StimulationId_Label_0A                          0x0000810a // 33034
#define OVTK_StimulationId_Label_0B                          0x0000810b // 33035
#define OVTK_StimulationId_Label_0C                          0x0000810c // 33036
#define OVTK_StimulationId_Label_0D                          0x0000810d // 33037
#define OVTK_StimulationId_Label_0E                          0x0000810e // 33038
#define OVTK_StimulationId_Label_0F                          0x0000810f // 33039
#define OVTK_StimulationId_Label_10                          0x00008110 // 33040
#define OVTK_StimulationId_Label_11                          0x00008111 // 33041
#define OVTK_StimulationId_Label_12                          0x00008112 // 33042
#define OVTK_StimulationId_Label_13                          0x00008113 // 33043
#define OVTK_StimulationId_Label_14                          0x00008114 // 33044
#define OVTK_StimulationId_Label_15                          0x00008115 // 33045
#define OVTK_StimulationId_Label_16                          0x00008116 // 33046
#define OVTK_StimulationId_Label_17                          0x00008117 // 33047
#define OVTK_StimulationId_Label_18                          0x00008118 // 33048
#define OVTK_StimulationId_Label_19                          0x00008119 // 33049
#define OVTK_StimulationId_Label_1A                          0x0000811a // 33050
#define OVTK_StimulationId_Label_1B                          0x0000811b // 33051
#define OVTK_StimulationId_Label_1C                          0x0000811c // 33052
#define OVTK_StimulationId_Label_1D                          0x0000811d // 33053
#define OVTK_StimulationId_Label_1E                          0x0000811e // 33054
#define OVTK_StimulationId_Label_1F                          0x0000811f // 33055
#define OVTK_StimulationId_LabelEnd                          0x000081ff // 33279
#define OVTK_StimulationId_Train                             0x00008201 // 33281
#define OVTK_StimulationId_Beep                              0x00008202 // 33282
#define OVTK_StimulationId_DoubleBeep                        0x00008203 // 33283
#define OVTK_StimulationId_EndOfFile                         0x00008204 // 33284
#define OVTK_StimulationId_Target                            0x00008205 // 33285
#define OVTK_StimulationId_NonTarget                         0x00008206 // 33286
#define OVTK_StimulationId_TrainCompleted                    0x00008207 // 33287
#define OVTK_StimulationId_Reset                             0x00008208 // 33288
GDF stimulation codes translated into OpenViBE
#define OVTK_GDF_Artifact_EOG_Large                               0x101 // 257
#define OVTK_GDF_Artifact_ECG                                     0x102 // 258
#define OVTK_GDF_Artifact_EMG                                     0x103 // 259
#define OVTK_GDF_Artifact_Movement                                0x104 // 260
#define OVTK_GDF_Artifact_Failing_Electrode                       0x105 // 261
#define OVTK_GDF_Artifact_Sweat                                   0x106 // 262
#define OVTK_GDF_Artifact_50_60_Hz_Interference                   0x107 // 263
#define OVTK_GDF_Artifact_Breathing                               0x108 // 264
#define OVTK_GDF_Artifact_Pulse                                   0x109 // 265
#define OVTK_GDF_Artifact_EOG_Small                               0x10A // 266
#define OVTK_GDF_Calibration                                      0x10F // 271
#define OVTK_GDF_EEG_Sleep_Splindles                              0x111 // 273
#define OVTK_GDF_EEG_K_Complexes                                  0x112 // 274
#define OVTK_GDF_EEG_Saw_Tooth_Waves                              0x113 // 275
#define OVTK_GDF_EEG_Idling_EEG_Eyes_Open                         0x114 // 276
#define OVTK_GDF_EEG_Idling_EEG_Eyes_Closed                       0x115 // 277
#define OVTK_GDF_EEG_Spike                                        0x116 // 278
#define OVTK_GDF_EEG_Seizure                                      0x117 // 279
#define OVTK_GDF_VEP                                              0x121 // 289
#define OVTK_GDF_AEP                                              0x122 // 290
#define OVTK_GDF_SEP                                              0x123 // 291
#define OVTK_GDF_TMS                                              0x12F // 303
#define OVTK_GDF_SSVEP                                            0x131 // 305
#define OVTK_GDF_SSAEP                                            0x132 // 306
#define OVTK_GDF_SSSEP                                            0x133 // 307
#define OVTK_GDF_Start_Of_Trial                                   0x300 // 768
#define OVTK_GDF_Left                                             0x301 // 769
#define OVTK_GDF_Right                                            0x302 // 770
#define OVTK_GDF_Foot                                             0x303 // 771
#define OVTK_GDF_Tongue                                           0x304 // 772
#define OVTK_GDF_class5                                           0x305 // 773
#define OVTK_GDF_Down                                             0x306 // 774
#define OVTK_GDF_class7                                           0x307 // 775
#define OVTK_GDF_class8                                           0x308 // 776
#define OVTK_GDF_class9                                           0x309 // 777
#define OVTK_GDF_class10                                          0x30A // 778
#define OVTK_GDF_class11                                          0x30B // 779
#define OVTK_GDF_Up                                               0x30C // 780
#define OVTK_GDF_Feedback_Continuous                              0x30D // 781
#define OVTK_GDF_Feedback_Discrete                                0x30E // 782
#define OVTK_GDF_Cue_Unknown_Undefined                            0x30F // 783
#define OVTK_GDF_Beep                                             0x311 // 785
#define OVTK_GDF_Cross_On_Screen                                  0x312 // 786
#define OVTK_GDF_Flashing_Light                                   0x313 // 787
// SPECIALY ADDED BY YR
#define OVTK_GDF_End_Of_Trial                                     0x320 // 800
#define OVTK_GDF_Correct                                          0x381 // 897
#define OVTK_GDF_Incorrect                                        0x382 // 898
#define OVTK_GDF_End_Of_Session                                   0x3F2 // 1010
#define OVTK_GDF_Rejection                                        0x3FF // 1023
#define OVTK_GDF_OAHE                                             0x401 // 1025
#define OVTK_GDF_RERA                                             0x402 // 1026
#define OVTK_GDF_CAHE                                             0x403 // 1027
#define OVTK_GDF_CSB                                              0x404 // 1028
#define OVTK_GDF_Sleep_Hypoventilation                            0x405 // 1029
#define OVTK_GDF_Maximum_Inspiration                              0x40E // 1038
#define OVTK_GDF_Start_Of_Inspiration                             0x40F // 1039
#define OVTK_GDF_Wake                                             0x410 // 1040
#define OVTK_GDF_Stage_1                                          0x411 // 1041
#define OVTK_GDF_Stage_2                                          0x412 // 1042
#define OVTK_GDF_Stage_3                                          0x413 // 1043
#define OVTK_GDF_Stage_4                                          0x414 // 1044
#define OVTK_GDF_REM                                              0x415 // 1045
#define OVTK_GDF_Lights_On                                        0x420  // 1056
#define OVTK_GDF_Lights_Off                                       0x8420 // 33824
#define OVTK_GDF_Eyes_Left                                        0x431 // 1073
#define OVTK_GDF_Eyes_Right                                       0x432 // 1074
#define OVTK_GDF_Eyes_Up                                          0x433 // 1075
#define OVTK_GDF_Eyes_Down                                        0x434 // 1076
#define OVTK_GDF_Horizontal_Eye_Movement                          0x435 // 1077
#define OVTK_GDF_Vertical_Eye_Movement                            0x436 // 1078
#define OVTK_GDF_Rotation_Clockwise                               0x437 // 1079
#define OVTK_GDF_Rotation_Counterclockwise                        0x438 // 1080
#define OVTK_GDF_Eye_Blink                                        0x439 // 1081
#define OVTK_GDF_Left_Hand_Movement                               0x441 // 1089
#define OVTK_GDF_Right_Hand_Movement                              0x442 // 1090
#define OVTK_GDF_Head_Movement                                    0x443 // 1091
#define OVTK_GDF_Tongue_Movement                                  0x444 // 1092
#define OVTK_GDF_Swallowing                                       0x445 // 1093
#define OVTK_GDF_Biting                                           0x446 // 1094
#define OVTK_GDF_Foot_Movement                                    0x447 // 1095
#define OVTK_GDF_Foot_Right_Movement                              0x448 // 1096
#define OVTK_GDF_Arm_Movement                                     0x449 // 1097
#define OVTK_GDF_Arm_Right_Movement                               0x44A // 1098
#define OVTK_GDF_ECG_Fiducial_Point_QRS_Complex                   0x501 // 1281
#define OVTK_GDF_ECG_P_Wave                                       0x502 // 1282
#define OVTK_GDF_ECG_QRS_Complex                                  0x503 // 1283
#define OVTK_GDF_ECG_R_Point                                      0x504 // 1284
#define OVTK_GDF_ECG_T_Wave                                       0x506 // 1285
#define OVTK_GDF_ECG_U_Wave                                       0x507 // 1286
#define OVTK_GDF_Start                                            0x580 // 1408
#define OVTK_GDF_25_Watt                                          0x581 // 1409
#define OVTK_GDF_50_Watt                                          0x582 // 1410
#define OVTK_GDF_75_Watt                                          0x583 // 1411
#define OVTK_GDF_100_Watt                                         0x584 // 1412
#define OVTK_GDF_125_Watt                                         0x585 // 1413
#define OVTK_GDF_150_Watt                                         0x586 // 1414
#define OVTK_GDF_175_Watt                                         0x587 // 1415
#define OVTK_GDF_200_Watt                                         0x588 // 1416
#define OVTK_GDF_225_Watt                                         0x589 // 1417
#define OVTK_GDF_250_Watt                                         0x58A // 1418
#define OVTK_GDF_275_Watt                                         0x58B // 1419
#define OVTK_GDF_300_Watt                                         0x58C // 1420
#define OVTK_GDF_325_Watt                                         0x58D // 1421
#define OVTK_GDF_350_Watt                                         0x58E // 1422
#define OVTK_GDF_Condition(i)                                       (i)
#define OVTK_GDF_Start_Of_New_Segment                            0x7FFE // 32766
#define OVTK_GDF_Non_Equidistant_Sampling_Value                  0x7FFF // 32767
This entry was posted in Data formats documentation and tagged . Bookmark the permalink.
