This page resumes all posts that address technical points and are not part of the user manual, documentation or the FAQ.
Troubleshooting
- Addressing low BCI accuracy - Error sources & solutions
- Build fails with "nmake failed to compile a simple program"
- Tutorial - Level 2 - Troubleshooting OpenViBE scenarios
Development
Design notes
Data-analysis
Deprecated and old documents
- CoAdapt P300 Stimulator - some design notes
- Compiling on Fedora 14
- P300: CoAdapt P300 Speller (OpenViBE v0.18 only)
- P300: Inserm P300 Speller
- Send stimulations from your application to the Acquisition Server
- Special features: Box messaging basics
- Special features: Box messaging for developers
- Tuning the build process - pre 0.16.0
- Using the basic P300 example scenarios of OpenViBE
Version migration instructions
- Differences between 1.x and 2.x series of OpenViBE
- Migrating a driver from 0.15.0 to 0.16.0
- Migrating a plugin from version 0.15.0 to 0.16.0
- Migrating box code from 0.18.x to 1.0.0
- Migrating your application from 0.15.0 to 0.16.0
- Migrating your code from 0.15.0 to 0.16.0
