Id-generator
Introduction
The id-generator is a simple command line tool that generate for you a set of random OpenViBE identifiers. These objects identifies pretty much everything in the software, from input types to algorithm triggers. Each of these identifier must be unique.
How to use it ?
Simply run the script openvibe-id-generator.cmd. (ov-id-generator.sh on Linux). Then copy-paste the identifier definition in your code. Please note that we provide only the prefix of the identifier and its code. You have to complete the name of the identifier.
id-generator (Windows)
This entry was posted in Developer tools. Bookmark the permalink.
