OpenViBE forum
The OpenViBE community
It is currently Tue Aug 20, 2019 2:44 am
Post new topic Reply to topic  [ 4 posts ]
Author Message
PostPosted: Tue Jul 31, 2018 2:44 am
Offline
Hello,
I am conducting analysis using the motor imagery data. I see the list of stimulation codes (http://openvibe.inria.fr/stimulation-codes/) however these do not correlate to the numbers in the dataset.
For example I'm seeing decimal numbers such as 1009, 9000, 785, 9001, 768, 769, 781, 800, etc. When I convert these to hexadecimal I am not seeing those hex values on the list of stimulation codes. Please let me know if there is anything I am overlooking, I appreciate your help!
Thank You!
Top
 Profile
PostPosted: Tue Jul 31, 2018 3:10 am
Offline
To be clear, I have found the hexadecimal equivalent of some of the stimulation codes. However I cannot find the stimulation codes associated with the following decimal values:
1009
9000
9001
33284
Top
 Profile
PostPosted: Tue Jul 31, 2018 7:31 am
Offline
Hello, 33284 is the end of file code.
Its possible that the other numbers are some custom codes introduced by the experimenter. If the dataset documentation doesn't describe this, the only possible recourse seems to be to contact the dataset authors (see the referred scientific paper). However, its possible they don't remember, after all the years.
Best,
Jussi
Top
 Profile
PostPosted: Sun Dec 23, 2018 9:31 pm
Offline
Hi,
I want to run motor imagery experiment with 4 , and 6 classes. I was able to do that with 4 classes which has relevant stimulation codes(Up,Down,Left, Right). And the stimulation code for cross that appear exist, which provide a much easier way to increase the classes to 4. How do I create another stimulation code that shows something like the cross with 6 partitions?
Thanks!
Umar
Top
 Profile
Who is online
Search for:
Jump to:
cron
Americanized by Maƫl Soucaze.
