the EEG signal unit
Frank94
the EEG signal unit
Post by Frank94 »
Hi There,
I use eego to acquire the EEG in motor-imagery-CSP scenario, and transfer the .ov to .edf. I import the file.edf to the eeglab for analyzing. When I see the signal, there is no unit. How can I know the EEG signal unit?
Looking forward to your reply
sincerely, Frank
Thanks!
Re: the EEG signal unit
Hello, you need to connect another stream called 'Channel Units' stream from the acquisition client box to the signal display box. The toolbar in the display should reveal a button to show or hide the units.
