OpenViBE forum
The OpenViBE community
It is currently Tue Mar 26, 2019 12:33 am
Post new topic Reply to topic  [ 5 posts ]
Author Message
PostPosted: Thu May 10, 2018 3:58 pm
Offline
Hi guys
I am creating a liason between emotic, openVibe and Unity3D.
-> I connect Emotic with Terminal ( it's connect to OpenVibe)
-> In Unity 3D, I creat the VR environment, and the stream, markers...
-> in open Vibe, I follow the Motor-Imagery CSP scenario.
So I question myself what's the next step after?
Cause i read a lot of papers but I don't find a clear solution?
Thank you.
Top
 Profile
PostPosted: Mon May 21, 2018 5:04 pm
Offline
Hi,
as far as I understand you'd want to send the predictions of the motor imagery online scenario (classifier processor box) to Unity. This could be done with various different ways, such as LSL, vrpn, or tcp writer. I think some users have managed to do it before (try google 'openvibe unity' or similar). The communication methods are briefly described on
http://openvibe.inria.fr/overview-sendi ... -openvibe/
The markers can be sent from Unity to acquisition server using TCP Tagging.
If this communication between OV/Unity is not what you meant, please be more specific. :)
Best,
Jussi
Top
 Profile
PostPosted: Wed May 23, 2018 7:35 pm
Offline
Hi
Thanks for your answer.
In fact I take this code : https://github.com/xfleckx/LSL4Unity to put on Unity.
In Unity, I saw the samples scrolled.
But my object actually doesn't move.
So I don't know how to use what kind of scenarios in OpenVibe.
I've heard of Lsl as driver but it's unstable.
Ok i will check it :)
Top
 Profile
PostPosted: Thu May 31, 2018 9:52 am
Offline
I met a problem.
I must to transform a VRPN Stream to a set of LSL streams.
But how can I do it?
Top
 Profile
PostPosted: Mon Jun 04, 2018 4:06 pm
Offline
Hi everyone
So i worked about this problems.
Maybe I find the scenario. But talking with a friend he told me how I use an LSL stream for Unity I have to convert it to transform a VRPN Stream to a set of LSL streams. to Write with a python script or a c++ app implementing the vrpn client and on each message recieved it would select or aggregate the data and push it as samples to an LSL stream.
But how can i find these kinds of scripts? thank you.
Top
 Profile
Who is online
Search for:
Jump to:
cron
Americanized by Maƫl Soucaze.
