OpenViBE forum
The OpenViBE community
It is currently Tue Mar 26, 2019 12:05 am
Post new topic Reply to topic  [ 1 post ]
Author Message
PostPosted: Tue Apr 24, 2018 9:40 am
Offline
Dear all,
I am trying to compile the sample code for VRPN Generic Server from here : http://openvibe.inria.fr/vrpn-tutorial- ... -openvibe/
I have configured my Visual Studio 2013 project to include all header files and VRPN library (vrpn.lib, vrpnd.lib, quat.lib, quatd.lib). But when I compile the program, it generates this error messages:
Error 1 error LNK2019: unresolved external symbol "public: static class GenericVRPNServer * __cdecl GenericVRPNServer::getInstance(int)" (?getInstance@GenericVRPNServer@@SAPAV1@H@Z) referenced in function _main D:\FOLDER\SOURCE_CODE\VRPN3\VRPN3\VRPN.obj VRPN3
Error 2 error LNK2019: unresolved external symbol "public: void __thiscall GenericVRPNServer::loop(void)" (?loop@GenericVRPNServer@@QAEXXZ) referenced in function _main D:\FOLDER\SOURCE_CODE\VRPN3\VRPN3\VRPN.obj VRPN3
Error 3 error LNK2019: unresolved external symbol "public: void __thiscall GenericVRPNServer::addButton(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,int)" (?addButton@GenericVRPNServer@@QAEXV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@H@Z) referenced in function _main D:\FOLDER\SOURCE_CODE\VRPN3\VRPN3\VRPN.obj VRPN3
Error 4 error LNK2019: unresolved external symbol "public: void __thiscall GenericVRPNServer::changeButtonState(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,int,int)" (?changeButtonState@GenericVRPNServer@@QAEXV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@HH@Z) referenced in function _main D:\FOLDER\SOURCE_CODE\VRPN3\VRPN3\VRPN.obj VRPN3
Error 5 error LNK2019: unresolved external symbol "public: int __thiscall GenericVRPNServer::getButtonState(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,int)" (?getButtonState@GenericVRPNServer@@QAEHV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@H@Z) referenced in function _main D:\FOLDER\SOURCE_CODE\VRPN3\VRPN3\VRPN.obj VRPN3
Error 6 error LNK2019: unresolved external symbol "public: void __thiscall GenericVRPNServer::addAnalog(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,int)" (?addAnalog@GenericVRPNServer@@QAEXV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@H@Z) referenced in function _main D:\FOLDER\SOURCE_CODE\VRPN3\VRPN3\VRPN.obj VRPN3
Error 7 error LNK2019: unresolved external symbol "public: void __cdecl GenericVRPNServer::changeAnalogState(class std::basic_string<char,struct std::char_traits<char>,class std::allocator<char> >,...)" (?changeAnalogState@GenericVRPNServer@@QAAXV?$basic_string@DU?$char_traits@D@std@@V?$allocator@D@2@@std@@ZZ) referenced in function _main D:\FOLDER\SOURCE_CODE\VRPN3\VRPN3\VRPN.obj VRPN3
Error 8 error LNK1120: 7 unresolved externals D:\FOLDER\SOURCE_CODE\VRPN3\Debug\VRPN3.exe VRPN3
I am suspicious this error appears because my Visual Studio does not find the respective library files. Is there another library that I should include to?
Please help me. Thank you.
Top
 Profile
Who is online
Users browsing this forum: Google [Bot] and 1 guest
Search for:
Jump to:
cron
Americanized by Maƫl Soucaze.
