VRPN Client with Qt Creator
Dox
Post by Dox »
Hi!
I am trying to build a VRPN client using Qt Creator as an IDE. I need Qt Creator because I am using it to the User interface and I wanted to add to my project a vrpn client.
So I followed the openVibe tutorial but I got some linking error:
C:\Document\ConnectVRPN\main.cpp:33: erreur : undefined reference to `vrpn_Button_Remote::vrpn_Button_Remote(char const*, vrpn_Connection*)'
C:\Documents\ConnectVRPN\main.cpp:40: erreur : undefined reference to `vrpn_Analog_Remote::vrpn_Analog_Remote(char const*, vrpn_Connection*)'
collect2.exe:-1: erreur : error: ld returned 1 exit status
my .pro file is as followed:
TEMPLATE = app
CONFIG += console c++11
CONFIG -= app_bundle
CONFIG -= qt
SOURCES += main.cpp
win32:CONFIG(release, debug|release): LIBS += -L$$PWD/vrpn/lib/ -lvrpn
else:win32:CONFIG(debug, debug|release): LIBS += -L$$PWD/vrpn/lib/ -lvrpnd
win32:CONFIG(release, debug|release): LIBS += -L$$PWD/vrpn/lib/ -lquat
else:win32:CONFIG(debug, debug|release): LIBS += -L$$PWD/vrpn/lib/ -lquatd
INCLUDEPATH += $$PWD/vrpn/include
DEPENDPATH += $$PWD/vrpn/include
here is my code:
#include <iostream>
#include "vrpn/include/vrpn_Button.h"
#include "vrpn/include/vrpn_Analog.h"
void VRPN_CALLBACK vrpn_button_callback(void* user_data, vrpn_BUTTONCB button)
    std::cout << "Button ID : " << button.button << " / Button State : " << button.state << std::endl;
    if (button.button == 1)
        *(bool*)user_data = false;
void VRPN_CALLBACK vrpn_analog_callback(void* user_data, vrpn_ANALOGCB analog)
    for (int i = 0; i < analog.num_channel; i++)
        std::cout << "Analog Channel : " << i << " / Analog Value : " << analog.channel[i] << std::endl;
int main(int argc, char** argv)
    /* flag used to stop the program execution */
    bool running = true;
    /* VRPN Button object */
    vrpn_Button_Remote* VRPNButton;
    /* Binding of the VRPN Button to a callback */
    VRPNButton = new vrpn_Button_Remote( "openvibe_vrpn_button@localhost" );
    VRPNButton->register_change_handler( &running, vrpn_button_callback );
    /* VRPN Analog object */
    vrpn_Analog_Remote* VRPNAnalog;
    /* Binding of the VRPN Analog to a callback */
    VRPNAnalog = new vrpn_Analog_Remote( "openvibe_vrpn_analog@localhost" );
    VRPNAnalog->register_change_handler( NULL, vrpn_analog_callback );
    /* The main loop of the program, each VRPN object must be called in order to process data */
    while (running)
        VRPNButton->mainloop();
    return 0;
I also put the dependancies folder next to my .pro file (the path is good because include directive works).
I haven't the vrpn.a may be it's why it doesn't link well but I don't know how to find this file.
If you have succeed to build a vrpn client with Qt or you have any idea, please tell me.
Re: VRPN Client with Qt Creator
That is a bit odd. It shouldn't need more than correct include/lib paths and linking the libs. Two ideas,
1) did you pick the same version of vrpn that openvibe uses? This can be found by either running the dependency installer from the OV source package or by a direct download (links may change over time),
http://openvibe.inria.fr/dependencies/w ... 31-dev.zip
http://openvibe.inria.fr/dependencies/w ... untime.zip
2) are you sure its even trying to link the vrpn lib when compiling? I'm not familar with the qt syntax. Maybe you can have some way to know this, like increasing verbosity.
Dox
Post by Dox »
(sorry for this late answer)
I have the same version of vrpn than openvibe. I get lib and include after running the dependency installer from the OV source package (and I also tried with direct download).
I am pretty sure that it's a linking trouble, because Qt see well the include files, but compilation failed when I try to declare an instance of a 'vrpn_Button_Remote::vrpn_Button_Remote' for example.
Anyone can try to link vrpn client with Qt creator?
tgaugry
Post by tgaugry »
Syntax seems to have changed for qmake.
If I believe http://doc.qt.io/qt-5/qmake-variable-reference.html, section "LIB", it seems that you should use this syntax
win32:LIBS += c:/mylibs/math.lib
Can you try this out ?
If that does not solve it, can you tell us your Qt version ? (since you are using qmake)
Another pointer would be checking path are corrects using message command in qmake.
Hope that helps,
Dox
Post by Dox »
I tried it, but it doesn't change...
my Qt version:
