Hello, I am a student researcher working with openvibe via NeuroSky Mindwave.
This is what I have done so far.
http://www.fast-files.com/getfile.aspx?file=118925This is the link for the xml.
However, I looked at other scenarios which looks a lot simpler. Also, I couldn't connect the filtered signal to python...
What do I have to do in python(which I'm not actually good at...)to divide the single-channel raw data to
http://support.neurosky.com/kb/science/eeg-band-frequencies these ranges?
And I need the values for the precise intensity of the ranges(Do I need to use NumPy and IPython???). Then I need to print these intensity values to csv.
I need to analyze values for scientific purposes.
It would be a lot for me if there was a python code example too.
Thank you very much for your cooperation.
If there are any links in the forum, please post them.
