Skeleton-Generator doesn't want generate
DarkPatate
Post by DarkPatate »
I want try to realise a box. Hence, I follow this tutorial: http://openvibe.inria.fr/tutorial-1-imp ... ssing-box/
Unfortunatlly, when I want generate my file, I can't find the folder: contrib/plugins/processing/signal-processing/src/. If I try to generate into another folder, the generation failed. I use the Windows version here, I don't try with the Linux one.
Thanks in advance!
Siméon.
gserrier
Re: Skeleton-Generator doesn't want generate
Post by gserrier »
Hi Siméon,
The folder should be in the openvibe directory which is create when you get the source code of OpenViBE.
About the generation, i will need the logs that are in the console that is launch when the generator start. Could you please copy/paste them.
Guillaume
DarkPatate
I tried with my Linux version and it's work perfectly, I found the folder. For my Windows version, I dont built the sources but I used the wizard.
When I'll restart my Windows I'll paste the log file.
DarkPatate
Here is the log file.
Moreover, at the end, the console displays:
(openvibe-skeleton-generator.exe:2896): Gtk-CRITICAL **: gtk_text_buffer_emit_in
sert: assertion `g_utf8_validate (text, len, NULL)' failed
Maybe it's because my first name has an acute? But I think I'll use the Linux version, it'll be easier.
openvibe-skeleton-generator.log
(5.65 KiB) Downloaded 315 times
