i have setup the code and was trying to debug it to find the reason why Mind Wave is not working and i ran into a problem, when i run ov-acquisition-server.cmd i am not able to see mindset in the driver list (attached image).
so i was not able to continue further, can you please help? if i can find it in the list i can further debug the code.
Thank you,
Chaithnya.
Not able to see mindset in the driver list
- open vibe.PNG (37.34 KiB) Viewed 4508 times
