I tried script linux-box-algorithm-wizard under mac Os to build a new box and even the script execute itself, it ended with a line of error : "line 145 :seq command not found" \ "logout".
What does it mean?
no files were created but in case of, where would they appear?
wizard script
Re: wizard script
matthieuG,
seq is a simple program that generates a sequence of numbers. You can read the manual if you want to have a better idea of how it works. It is part of the basic GNU tools. I expected it would be included on MAC but maybe it's not. I don't have a MAC myself so I can't test / help more on this. Either you have time to update the script on MAC and I am interested in this contribution, either you don't have time and you should move to Linux to make this script work As I told you in previous messages, this would also work on Windows with Cygwin.
