Failed to find Emotiv API
chantrip
Post by chantrip »
Dear Openvibe team
I have Epoc driver installed at 'C:\Program Files\Emotiv Research Edition SDK_v1.0.0.5-PREMIUM' and have tried to install Openvibe13. My OS is Windows 7. However, when I run win32-build, the log message attached here shows 'Failed to find Emotiv API' and I cannot use EPOC with Openvibe. Could you please tell me how to fix this problem?
Thank you very much
-Jim
jlegeny
Re: Failed to find Emotiv API
Post by jlegeny »
Hello Jim,
the path to the version 1.0.0.5 of the Emotiv SDK is indeed missing in the Cmake file. In order to fix your problem edit the cmake-modules/FindThirdPartyEmotivAPI.cmake file and insert this two following lines to the FIND_PATH statement
"C:\Program Files\Emotiv Research Edition SDK_v1.0.0.5-PREMIUM"
"C:\Program Files\Emotiv Research Edition SDK_v1.0.0.5-PREMIUM/doc/examples/include"
We will include this fix in the svn. Thank you for the heads up.
Yourka
Post by Yourka »
i've a similar problem,
i'm running on Ubuntu 14.04, the openvibe compilatino works except the "FAILED to find Emotiv API".
the problem is that Emotiv is not using (see #) anymore.
        "C:/Program Files/Emotiv Development Kit*"
        "C:/Program Files/Emotiv Research Edition*"
        "/home/{username}/EmotivResearch_2.0.0.20*"
i've asked Emotiv what to use instead, they linked me that file : https://github.com/Emotiv/community-sdk which has nothing about how to use it.
can you help me on finding the path to find the Emotiv API ?
thank you,
Guillaume Doncieux
