P300 speller issues in replay scenario in version 3.0.0
m.casso-echalar
Post by m.casso-echalar »
Hello!
While using the example scenario p300 speller, I had the following remarks:
and the following errors:
I first tried to follow the solution presented this topic: viewtopic.php?f=16&t=10166&p=16527&hili ... ine#p16527 by updating each submodule to the last commit- since I was not having feedback on the online scenario for the same example- but it did not work.
Please if you have any comments, they would be very much appreciated!
Re: P300 speller issues in replay scenario in version 3.0.0
HI,
If box are not white, there is a problem....
Red, is for box doesn't exist. I think you haven't run the good designer, it's in dist/extra not in dist/designer.
