Where has the box window gone in openvibe 3.0?
reconnel
Post by reconnel »
I recently downloaded the newest version of OpenVibe. On previous versions the designer came with a section on the right hand side where you could search for boxes. This does not seem to be visible in the newest version of OpenVibe. Does anyone know how I find and add boxes to a scenario in the newest version of Openvibe? Is there some settings I need to change?
reconnel
Re: Where has the box window gone in openvibe 3.0?
Post by reconnel »
Never mind, I found it, it was just squished all the way to the edge of the screen, making it invisible.
remi
Post by remi »
Thanks for the info, I was just looking for the Boxes window too, thought it was missing in OpenVibe 3 !!!
In order to retrieve it, you need to click on the far right of the screen and pull to the left while holding the mouse button.
This bug can appear some times but I don't know why. The panel is only retract on right but when we don't know this it can be disturbing.
