When i build the OpenVibe with my driver i receive the next mistake
Ron
Post by Ron »
Hello, I wanted to add a driver for my developed device to OpenVibe. I did as it is written in the instructions on the site http://openvibe.inria.fr/tutorial-creat ... on-server/ - "Including the driver to the server" .
I put my driver to contrib/plugins/server-drivers/my_driver/src/
After that i changed the next files: contribAcquisitionServer.inl
contribAcquisitionServer.cmake
contribAcquisitionServerLinkLibs.cmake
And I after that I started to build (sh build.sh). But every time when i try do it, i receive the next mistake in my Ubuntu -
CMakeFiles/Makefile2:1494: recipe for target 'applications/platform/acquisition-server/CMakeFiles/openvibe-acquisition-server.dir/all' failed
make[1]: *** [applications/platform/acquisition-server/CMakeFiles/openvibe-acquisition-server.dir/all] Error 2
Makefile:127: recipe for target 'all' failed
make: *** [all] Error 2
build.sh: 72: build.sh: [[: not found "
Without my driver, i can build the OpenVibe. Where can be a problem, maybe need to change some files yet?
Re: When i build the OpenVibe with my driver i receive the next mistake
Post by Thomas »
Hi Ron,
Looks like you're going in the right direction. Could you share the files you changed so I can have a look at them ?
Thank you
