Motor Imagery online scenario - lua terminated
Akshaya
Post by Akshaya »
Hi everyone,
I used the default motor imagery and got and accuracy with the trainer. But after training when I check the online scenario I find that after the scenario is given for online test my program is running without terminating after online is done. I have attached it below.
Thank you very much in advance.
Akshaya.
online_motor imagery.PNG (92.99 KiB) Viewed 968 times
Re: Motor Imagery online scenario - lua terminated
I don't see all, give the xml file instead of screenshot it's easier for me to see directly the scenario.^^
But to stop the scenario you must have a player controller box who make an action (as pause or stop) when he received a stimulation (in parameter too).
