Stacked BitMap (Horizontal) scale
ammaia
Post by ammaia »
Hi!
Is there anyway to change the Y scale from the Stacked BitMap (Horizontal) ?
(It seems to have a default range from 0~125)
Re: Stacked BitMap (Horizontal) scale
The scale is automatic with the FFT Possibility, if you are une 256Hz the FFT is in 0-128Hz. You have the signal Decimation tu reduce the Frequency. Check in scenario example -> box-tutorials -> advanced-visualization.
If you don't understand any box check the example there are here for almost all boxes and they are easy to understand.
