Problem with acquisition server connection to a driver
Yael
Post by Yael »
Hi Everyone,
I am trying to connect to the driver "Brain product amplifiers [through brain vision recorder]", and I've encountered a few issues:
1. When connecting to port 51244 which is the port of the recorder and I've checked that is active, I receives an header error
"First message received is not an header!"
2.When connecting to port 51254 which is also active (this is an RDA server), the connection is a success, yet when I press play to start record there is a crush of a sort, the acquisition server window is being shut and in the cmd window The 2 last lines are:
Now acquiring
Press any key to continue.
Please help,
Yael
Re: Problem with acquisition server connection to a driver
I asked people using the brainproduct, they do not use the recorder provided with the headset but directly the OpenViBE acquisition server.
