OpenViBE forum
The OpenViBE community
It is currently Tue Aug 20, 2019 4:04 am
Post new topic Reply to topic  [ 3 posts ]
Author Message
 Post subject: p300 plot
PostPosted: Fri Apr 19, 2019 4:40 am
Offline
Hi,
I want to plot p300 auditory signal. I have a auditory signal with two different tone : regular(t1) and rare(t2) tone. I want to do
a)Want to add epochs with t1=e1
b)Want to add epochs with t2=e2
c)Want to subtract e3=e1-e2
d)Plot p300(e3)
Help please . See the attached eeg file in csv and tone.
Rafia
email: akhter.rafia1@gmail.com
t6.zip [175.87 KiB]
Downloaded 16 times
Top
 Profile
 Post subject: Re: p300 plot
PostPosted: Tue Apr 23, 2019 8:12 am
Offline
Hi,
If I understood, you wan't to substract and plot two differnt epochs.
In openvibe boxes already writen you can make process on current epoch, if you wan't to work with previous epochs, I think it's better to read your signal and make your process outside OpenViBE (with Python for example) and you make a new signal file with your substract and next plot to OpenViBE.
If you wan't to make this during online acquistion you can write a box who stack your epochs in two stack and make the output you wan't your e3. Take care if you wan't to stack too much informations release or limite the number of epochs.
Personally, I would make a scenario that uses a stream switch that will have 3 output (e1, e2, epoch useless). Then I would encode a box with two input (e1, e2) and I will have an e3 output and I remove epoches become useless as and when.
Thibaut
Top
 Profile
PostPosted: Tue Apr 23, 2019 1:39 pm
Offline
Thanks.
Top
 Profile
Who is online
Search for:
Jump to:
cron
Americanized by Maƫl Soucaze.
