Channel Localisation File Format
traviskv
Post by traviskv »
Hello!
Could anyone explain the electrode location format? I am attempting to generate 2D topographic maps. I am using a headset that consists of an Emotiv Epoc decoder and a cap/electrode system from another company. As such, my electrode locations are different from the default Emotiv Epoc electrode locations. I know where the electrode_set files are and to open them with a text editor, however the electrode_set file I edited to use in my experiment returns an error in the designer command prompt.
I am using 14 electrodes at "Nz" "FPz" "FC5" "FC6" "FC3" "FC4" "C5" "C6" "C3" "C4" "C1" "C2" "CP3" "CP4" (these correspond to channels 1 through 14 respectively). The Emotiv Epoc DRL and CMS electrodes are located at "P3" and "P4".
I've attached screenshots of my electrode layout, electrode_set text file, and screenshot of the error.
Thank you.
10-20 electrode layout
screenshot of error in command prompt
electrode_set.txt
(566 Bytes) Downloaded 122 times
Re: Channel Localisation File Format
The channels may not have the same name in your input signal.
If you make a signal display is the same?
traviskv
Post by traviskv »
Hello, Thibaut. Thank you for replying.
No, they are not the same. The incoming signal retains its Emotiv Epoc default channel labels. Can I override this?
I attempted to rename the channels in OV Acquisition Server (by renaming each channel under the "Driver Properties" settings), but it did not affect the signal as the channels still showed up as the default Emotiv Epoc designations.
signal display showing Emotiv Epoc channels
traviskv
Post by traviskv »
I think I understand the error now, but I still have a concern. I would like to assign new channel designations to my input signal. How can I do this? I mentioned earlier that I tried to reassign the channel designations using the OV Acquisition client, but that did not seem to work.
You have a channel rename box.
