Installing in Raspberry pi 3 b+
jeban83
Post by jeban83 »
Would appreciate if anyone could assist in installing openvibe in Raspbian running on pi 3 b+.
Re: Installing in Raspberry pi 3 b+
I haven't a Raspberry to test but check the build instruction in the Website : http://openvibe.inria.fr/build-instructions/
And tell us if you encounter a problem.
jeban83
Post by jeban83 »
The dependency script fails immediately, throwing a message that distribution is not supported. So alternatively I installed Ubuntu 16.04 and gave a try.
I initially tried installing openvibe 2.2, but ran into an issue with vrpn dependency. I read the forums but couldn't fix it. The next option I tried was to install openvibe 1.3. and after difficulties, I was able to install it.
I do have a Neurosky Mindwave headset and I need to use it. Unfortunately, the challenge that I am facing here is, the acquisition server is not detecting Neurosky headset.
Would be great if you could give some insights.
