OpenViBE forum
The OpenViBE community
It is currently Mon Mar 25, 2019 11:58 pm
Post new topic Reply to topic  [ 3 posts ]
Author Message
PostPosted: Mon Feb 25, 2019 8:51 am
Offline
Appreciate if anyone can throw some insight into how to install openvibe 2.2 in Raspberry Pi 3 Model B+ running Raspbian OS.
Top
 Profile
PostPosted: Wed Mar 13, 2019 1:30 pm
Offline
Hi,
it will have been long, but I found someone who had already succeed to compile on Raspbian an old version of openvibe (1.2.2).
On extra/CMakeLists.txt and sdk/CMakeLists.txt
comment with à # the line
Code:
SET(OV_EIGEN_FLAGS "-msse2")
He disable an optimization
in extra/application/demos/CMakeLists.txt
comment the line
Code:
OV_ADD_PROJECTS("APPLICATIONS_DEMOS")
He disable demos applications
He change an other thing for dependencies but they have change a lot since this old version.
Top
 Profile
PostPosted: Fri Mar 15, 2019 2:40 am
Offline
Hi,
Thanks for the response but this did not help. Getting the same error:
Compiling lsl ...
cp: cannot stat 'liblsl/build/src/liblsl.so': No such file or directory
Running extras/scripts//linux-dep-helpers//linux-compile-vrpn.pl ...
Compiling vrpn ...
cp: cannot stat 'vrpn/quat/pc_linux64/*.a': No such file or directory
cp: cannot stat 'vrpn/pc_linux64/*.a': No such file or directory
Running extras/scripts//linux-dep-helpers//linux-compile-itpp.pl ...
OpenViBE SDK dependencies were successfully installed
Any guidance,
Thanks
Top
 Profile
Who is online
Users browsing this forum: No registered users and 3 guests
Search for:
Jump to:
cron
Americanized by Maël Soucaze.
