OpenViBE forum
The OpenViBE community
It is currently Sun Feb 17, 2019 9:29 am
Post new topic Reply to topic  [ 2 posts ]
Author Message
 Post subject: python animation
PostPosted: Thu Jan 17, 2019 3:43 pm
Offline
I have a gauge animation indicating the power received. Ideally it should work in real-time. But, after initializing it and expecting it to change value as the program proceeds , I am stuck because the stimulations won't start until I close the figure(which was supposed to change values as the program proceeds). The code is below. I do not know how to get it to work in real-time. Also, is it possible for the figure to appear as part of the visualization window and not separately, it will be so convenient if this is possible for matplotlib figures to be embedded into the main visualization window:
Code:
import os, sys
import matplotlib
from matplotlib import cm
from matplotlib import pyplot as plt
import matplotlib.animation as animation
import time
from matplotlib.patches import Circle, Wedge, Rectangle
# let's define a new box class that inherits from OVBox
class MyOVBox(OVBox):
    def __init__(self):
        OVBox.__init__(self)
        # we add a new member to save the signal header information we will receive
        self.signalHeader = None
        self.threshold=0
        #stores the current chunk at anytime
        self.chunk=[0]
        self.fig,self.ax=plt.subplots()
    def initialize(self):
        self.threshold=float(self.setting['Threshold'])
        ani=animation.FuncAnimation(self.fig,self.animate,interval=30)
        plt.show()
    def animate(self,i):
        if (self.chunk[0]<=0.33*self.threshold):
                    self.ax.clear()
                    self.gauge(1)
        elif (self.chunk[0]<=0.66*self.threshold) and (self.chunk[0]>0.33*self.threshold):
                    self.ax.clear()
                    self.gauge(2)
        elif (self.chunk[0]<=self.threshold) and (self.chunk[0]>0.66*self.threshold):
                    self.ax.clear()
                    self.gauge(3)
        elif (self.chunk[0]<=1.33*self.threshold) and (self.chunk[0]>self.threshold):
                    self.ax.clear()
                    self.gauge(4)
        elif (self.chunk[0]<1.66*self.threshold) and (self.chunk[0]>1.33*self.threshold):
                    self.ax.clear()
                    self.gauge(5)
        else :
                    self.ax.clear()
                    self.gauge(6)
    def degree_range(self,n):
        start = np.linspace(0,180,n+1, endpoint=True)[0:-1]
        end = np.linspace(0,180,n+1, endpoint=True)[1::]
        mid_points = start + ((end-start)/2.)
        return np.c_[start, end], mid_points
    def rot_text(self,ang):
        rotation = np.degrees(np.radians(ang) * np.pi / np.pi - np.radians(90))
        return rotation
    def gauge(self,arrow=1):
        #fixed stuff
        labels=['LOW','MEDIUM','HIGH','VERY HIGH','EXTREME','CRITICAL']
        colors='YlOrRd_r'
        title='ERD level'
        N = len(labels)
        #if colors is a string, we assume it's a matplotlib colormap and we discretize in N discrete colors
        if isinstance(colors, str):
           cmap = cm.get_cmap(colors, N)
           cmap = cmap(np.arange(N))
           colors = cmap[::-1,:].tolist()
        if isinstance(colors, list):
            if len(colors) == N:
                colors = colors[::-1]
            else:
                raise Exception("\n\nnumber of colors {} not equal to number of categories{}\n".format(len(colors), N))
        ang_range, mid_points = self.degree_range(N)
        labels = labels[::-1]
        patches =[]
        for ang, c in zip(ang_range, colors):
            # sectors
            patches.append(Wedge((0.,0.), .4, *ang, facecolor='w', lw=2))
            # arcs
            patches.append(Wedge((0.,0.), .4, *ang, width=0.10, facecolor=c, lw=2, alpha=0.5))
            [self.ax.add_patch(p) for p in patches]
        #set the labels (e.g. 'LOW','MEDIUM',...)
        for mid, lab in zip(mid_points, labels):
            self.ax.text(0.35 * np.cos(np.radians(mid)), 0.35 * np.sin(np.radians(mid)), lab, horizontalalignment='center', verticalalignment='center', fontsize=14,             fontweight='bold', rotation = self.rot_text(mid))
        #set the bottom banner and the title
        r = Rectangle((-0.4,-0.1),0.8,0.1, facecolor='w', lw=2)
        self.ax.add_patch(r)
        self.ax.text(0, -0.05, title, horizontalalignment='center',verticalalignment='center', fontsize=22, fontweight='bold')
        #Arrow
        pos = mid_points[abs(arrow - N)]
        self.ax.arrow(0, 0, 0.225 * np.cos(np.radians(pos)), 0.225 * np.sin(np.radians(pos)),width=0.04, head_width=0.09, head_length=0.1, fc='k', ec='k')
        self.ax.add_patch(Circle((0, 0), radius=0.02, facecolor='k'))
        self.ax.add_patch(Circle((0, 0), radius=0.01, facecolor='w', zorder=11))
        #removes frame and ticks, and makes axis equal and tight
        self.ax.set_frame_on(False)
        self.ax.axes.set_xticks([])
        self.ax.axes.set_yticks([])
        self.ax.axis('equal')
        plt.tight_layout()
    def process(self):
        for chunkIndex in range( len(self.input[0]) ):
            if(type(self.input[0][chunkIndex]) == OVSignalBuffer):
                self.chunk=self.input[0].pop()
            elif(type(self.input[0][chunkIndex]) == OVSignalEnd):
                print 'Signal end reached'
            else:
# Finally, we notify openvibe that the box instance 'box' is now an instance of MyOVBox.
# Don't forget that step !!
box = MyOVBox()
Top
 Profile
 Post subject: Re: python animation
PostPosted: Fri Jan 18, 2019 9:29 am
Offline
Hi,
I have never used matplotlib for animation, but I think it must be pretty heavy as a system. Personally, I made a system as you describe it, but I coded it in C ++ in a specific box. For visualizations, I think you should turn to the visualization box implementation. Or use existing ones by passing them the information calculated by your script.
If you go about the implementation of a box, the Graz visualization displays a blue bar that evolves according to the data received (input amplitude) it could help you.
Thibaut
Top
 Profile
Who is online
Users browsing this forum: No registered users and 3 guests
Search for:
Jump to:
Americanized by Maƫl Soucaze.
