OpenViBE forum
The OpenViBE community
It is currently Sun Jan 20, 2019 2:47 pm
Post new topic Reply to topic  [ 3 posts ]
Author Message
PostPosted: Wed Dec 19, 2018 4:28 pm
Offline
Hi everyone,
I have some difficulties to connect the Gtech Nautilus device to the acquisition server.
The gNEEDacess is well installed and works normally, but I can't connect the device.
The following error message is display :
[ERROR] No Gtech device found
[ERROR] connection failed
I tested with the generic oscillator and it works.
Is there some configuration steps required before using the device ?
I found the following documentation (http://openvibe.inria.fr/openvibe/wp-co ... enViBE.pdf) Is this still up to date?
Thank you for your time.
Thibault.
(Moderator: moved post to its own topic)
Top
 Profile
PostPosted: Mon Jan 07, 2019 9:14 am
Offline
Hi,
I had several problems with the Nautilus. Turn on your headset before launching the acquisition server. I also click on "driver properties" before doing "connect".
Thibaut
Top
 Profile
PostPosted: Mon Jan 07, 2019 3:24 pm
Offline
Hi Thibaut,
It works,
Thanks.
Thibault.
Top
 Profile
Who is online
Search for:
Jump to:
cron
Americanized by Maƫl Soucaze.
