MOTOR IMAGERY CSP
AYDLINN
MOTOR IMAGERY CSP
Post by AYDLINN »
Good morning
I'm at the set 2 of the scenario. I'v a problem with CSP filter box. You know Why?
I've got a OPENBCI cyton board.
thank you
AYDLINN
Re: MOTOR IMAGERY CSP
Post by AYDLINN »
May be I need a recent version?
I do not see the problem apart from the chunk stimulation date but it does not matter
AYDLINN
Post by AYDLINN »
Hi thanks
I solved the problem:
-> by changing the address of each box
-> by checking the ports of each electrode
