Hi everyone,
I followed this instructions to try to do the connection between OpenVibe and Emotiv Epoc: http://openvibe.inria.fr/how-to-connect ... -openvibe/ .
But I have a problem,as can see below:
[ERROR] [INIT] Emotiv Driver: Failed to get the environment PATH.
I'm using the Emotiv Research v.1.0.0.5, can anyone help me?
Best regards,
Rafael
[ERROR] with Emotiv Research
- Attachments
- Sem título.jpg (208.82 KiB) Viewed 7358 times
Re: [ERROR] with Emotiv Research
Hi Rafael,
it seems that there is a bug in our code. If you press 'connect' before having updated the Emotiv path to point to the correct location, it looks like the process will unset the PATH environment variable. For us, a workaround seems to be if you quit the acquisition server, change the emotiv path to point to the correct location, and only after that press connect.
Does this work for you?
Best,
Jussi
Best,
Jussi
I've also been trying to connect my EMOTIV research addition to OpenVibe, however I'm using version 2.0.0.20 and Open Vibe doesn't seem to recognize the Emotive folder. Could this be a compatibility issue with the new version of the Research SDK? Or does the path need to be directed to the dll folder in the Research Edition folder?
- Attachments
- Error message
- Capture2.PNG (64.2 KiB) Viewed 7292 times
- Driver properties
- Capture1.PNG (53.4 KiB) Viewed 7292 times
Hello mmccart92,
Indeed it could be a problem with the API itself, OpenViBE is currently compiled only with the 1.0.0.x series of the SDK, it is possible that Emotiv did make some breaking changes in the v2.
We will look into this.
Regards
Jozef
Regards
Jozef
