How to send messages to the console?
Post Reply
ammaia
Post by ammaia »
I would like to know if it is possible to send messages to the INF console at the bottom of the OpenVibe screen designer.
Lets use a simple scenario connecting the 2 modules: "Clock stimulator" and "Run Command"
"Clock stimulator" defined as:
Code: Select all
Intervalstimulation interval (in sec): 10.00000
Stimluation: OVTK_StimulationId_Label_01
"Run Command" defined as:
Code: Select all
Stimulation 1: OVTK_StimulationId_Label_01
Command 1: START notepad
So, each 10 seconds it opens the application notepad.
What I want to do is also to send a message each 10 seconds to the console at the botton of the screen. For example: "Opening notepad..."
Regards
Pedro
jlegeny
Contact:
Re: How to send messages to the console?
Post by jlegeny »
Hello Pedro,
an easy way to display arbitrary messages would be to use the Lua stimulator box.
Add an input to it via right click menu and use it with a simple script such as this:
Code: Select all
function initialize(box)
function uninitialize(box)
function process(box)
	while true do
		if (box:get_stimulation_count(1)) then
			box:log("Info", "test")
			box:remove_stimulation(1, 1)
		box:sleep()
This program will display a message "test" every time it receives a stimulation. For more info look at the lua box documentation here:
http://openvibe.inria.fr/documentation/ ... lator.html
Cheers
Jozef
Post Reply
