OpenViBE forum
The OpenViBE community
It is currently Sun May 26, 2013 1:59 am
Post new topic Reply to topic  [ 22 posts ]  Go to page Previous  1, 2
Author Message
PostPosted: Fri Dec 03, 2010 11:05 pm
Offline
Hi all,
Hurray! For the first time, I was able to achieve 100% correct result (e.g. 91I59NI2RS) even though my Classifier performance was approx. 78% after the training phase.
Question 1.
What happens if I run/play multiple times in the "p300-speller-2-train-xDAWN.xml" (or "p300-speller-3-train-classifier") in the training phase? Does the new training gets accumulated and stored in the .ov file OR does it overwrite the previous training in the .ov file?
Question 2.
I would like to change the dimension of the P300 matrix. Also I would like to change the graphics? For example, 3 x 3 matrix with photos. Is there an easy way to do this?
Question 3.
If I had to remove some of the EEG sensors of the Emotiv EPOC headset to minimize the total number of sensors, which EEG sensors should I keep for P300-speller in the Emotiv?
Channel names in Emotiv headset based on the International 10-20 locations are: AF3, F7, F3, FC5, T7, P7, O1, O2, P8, T8, FC6, F4, F8, AF4
Question 4.
Any plans for OpenViBE technical conference? Or any recommendation for upcoming good BCI conferences?
Thank you so much!
David
Top
 Profile
PostPosted: Fri Dec 10, 2010 10:10 am
Offline
Site Admin
Dear davidchung,
congratulations for getting this to work ! 78% is not an excellent classifier performance in case of the P300 speller but with 12 repetitions, it indeed leads to correct detection. Did you try to play with the number of repetitions as well ?
davidchung wrote:
Question 1.
The training is not iterative. The data is recorded in separate files so you can train on any of them but not all of them. If you want more data to train on, just spell more letters in one session.
davidchung wrote:
Question 2.
Did you look at the Magic Card scenarios ?
davidchung wrote:
Question 3.
I recommand you read this article http://hal.archives-ouvertes.fr/hal-00517388
davidchung wrote:
Question 4.
There will be some OpenViBE workshop by the end of 2011 but not before this. If interested in BCI events, you should have a look at Fabien Lotte's dedicated page.
Hope this helps,
Yann
_________________
CTO at Mensia Technologies | Image my blog | Image my tweets | Image my linkedin
Top
 Profile
PostPosted: Tue Dec 21, 2010 2:05 am
Offline
yrenard wrote:
davidchung wrote:
Question 2.
Yann
I will create a new thread for this.
Top
 Profile
PostPosted: Tue Dec 28, 2010 11:31 pm
Offline
Hi
I am not sure how "p300-speller-4-online.xml" knows which training set to choose, if there are multiple "p300-speller-xdawn-4-[yyyy.mm.dd-hh.mm.ss].ov" files under \openvibe\dist\share\openvibe-scenarios\signals.
Thanks,
David
Top
 Profile
PostPosted: Mon Jan 03, 2011 9:59 am
Offline
Site Admin
Hi David,
The online scenario does not directly use the brain signal, but the configuration files generated during the training phase on this signal. These files are :
- openvibe-scenarios/bci/p300-speller-xDAWN/p300-spatial-filter.cfg for the xDAWN spatial filter box
- openvibe-scenarios/bci/p300-speller-xDAWN/p300-classifier-processor.cfg for each classifier processor box.
Every time your run the training scenarios (xDAWN and classifier) you generate new configuration files. The name of these files never change (it's the name provided in the classifier trainer box and the xDAWN spatial filter trainer box)
regards,
Laurent
_________________
Top
 Profile
PostPosted: Tue Jan 17, 2012 11:08 pm
Offline
which one help to indicate brain for working or any movement ?
_________________
william blake
Top
 Profile
PostPosted: Thu Oct 11, 2012 4:59 pm
Offline
Hello!
I am using the p300-speller-xDAWN scenario, trying to get some P300 using Emotiv. The 10-fold validation accuracy estimation I get is between 66-72%. When I try the online scenario, in the best case I get 1/20 letters detected. Really poor performance (almost random). I tried increasing the repetitions by changing the values of p300-speller-stimulator.cfg file, but nothing was improved.
Apart from changing the source filename in the xDawn training and the classifier training scenarios, is there something else I should change to improve performance with Emotiv? davidchung and yrenard, am I doing sth wrong?
Top
 Profile
Who is online
Search for:
Jump to:
cron
POWERED_BY
Translated by Maël Soucaze © 2009 phpBB.fr
