Hi,
I have worked with P300 speller scenario and it seems to work fine.
Now I am trying to train the classifier for the P300 speller using xDAWN and I have encountered the below error in xDAWN Spatial filter.
https://ibb.co/2tsmg9k
What could be the problem here?
Thank you
Regards
Yohan
Error in xDAWN Spatial Filter for P300 Speller
Re: Error in xDAWN Spatial Filter for P300 Speller
HI,
This bug were corrected in new version Of OpenViBE (coming soon^^) but you can use the other xdawn box (deprecated) while waiting or if you build from source code get the last developpement commit on all branch.
Thibaut
Thibaut
Hi YohanZwei02 ,
I have the exactly same error. Did you manage to find a solution?
