Dear Thibaut and Jussi,
I really need your help and guidance in connecting the Openvibe with the brain product recview software. the reason I need it is to use the openvibe in an MRI environment.
I've downloaded the RDAServer.dll file from the BCI2000 kit, and built the filter tree as bellow. Yet I was not able to record with the open vibe, I was hoping for your guidance with a few questions.
[image4.png][/img]
1. Do I need to download anything other than the RDAServer.dll that I saved in the recview? maybe from the "CopyToBCI2000_prog_directory" folder and copy to a place in the openvibe instead?
2. In order to work with the recview I need to first open the recorder, but I can't record from both the recorder and the openvibe acquisition server.
Do I need to open the acquisition server, what driver to choose? I usually choose the Brain Product BrainAmp series, but I also tried using the Brain Products amplifiers with no success.
[image2.png][/img]
3.I've also tried opening the recorder >>recview>> Openvibe designer only and entering the server port of the RDA client, yet with no success. Is there another box I should use?
[image3.png][/img]
[image4.png][/img]
I will be forever greatfull for any assistance and guidance you can give me.
Thanks,
Yael
Help request
Help request
- Attachments
- image4.png (55.28 KiB) Viewed 30658 times
- image3.png (46.1 KiB) Viewed 30658 times
- image2.png (91.71 KiB) Viewed 30658 times
