OpenViBE forum
The OpenViBE community
It is currently Mon Jun 17, 2019 6:34 am
Post new topic Reply to topic  [ 3 posts ]
Author Message
PostPosted: Wed Feb 27, 2019 7:34 am
Offline
Would appreciate if anyone could assist in installing openvibe in Raspbian running on pi 3 b+.
Top
 Profile
PostPosted: Thu Feb 28, 2019 12:49 pm
Offline
I haven't a Raspberry to test but check the build instruction in the Website : http://openvibe.inria.fr/build-instructions/
And tell us if you encounter a problem.
Top
 Profile
PostPosted: Tue Mar 05, 2019 1:31 pm
Offline
The dependency script fails immediately, throwing a message that distribution is not supported. So alternatively I installed Ubuntu 16.04 and gave a try.
I initially tried installing openvibe 2.2, but ran into an issue with vrpn dependency. I read the forums but couldn't fix it. The next option I tried was to install openvibe 1.3. and after difficulties, I was able to install it.
I do have a Neurosky Mindwave headset and I need to use it. Unfortunately, the challenge that I am facing here is, the acquisition server is not detecting Neurosky headset.
Would be great if you could give some insights.
Thanks
Top
 Profile
Who is online
Search for:
Jump to:
cron
Americanized by Maƫl Soucaze.
