OpenViBE forum
The OpenViBE community
It is currently Tue Aug 20, 2019 2:45 am
Post new topic Reply to topic  [ 10 posts ]
Author Message
PostPosted: Sun Sep 02, 2018 12:01 pm
Offline
Hi,
I've seriously tried everything, yet I can't figure out what is the problem.
The matlab tutorials works fine, that means that there is no problem with the matlab engine calling, yet when I try to write a basic scenario the whole system crash.
Please help.
here are the matlab code (since I can't attach them as files):
Code:
function box_out = OV_EFP1_Initialize(box_in)
   disp('Matlab initialize function has been called.')
   box_out = box_in;
function box_out = OV_EFP1_Process(box_in)
 for i = 1: OV_getNbPendingInputChunk(box_in,1)
   [box_in, start_time, end_time, matrix_data] = OV_popInputBuffer(box_in,1);
   box_in = OV_addOutputBuffer(box_in,1,start_time,end_time,matrix_data);
    % Pass the modified box as output to continue processing
    box_out = box_in;
function box_out = OV_EFP1_Uninitialize(box_in)
   disp('Matlab uninitialize function has been called.')
   box_out = box_in;
Many thanks,
Yael
tryout1.xml [14.19 KiB]
Downloaded 84 times
Top
 Profile
PostPosted: Tue Sep 04, 2018 8:46 am
Offline
Hi,
So when I attach my code onto tutorial 2 code it works, but when I delete the parts of the tutorial that I don't need the system crash again. meaning the openvibe designer shutdown.
please what am I doing wrong?
Many thanks,
Yael
Top
 Profile
PostPosted: Wed Sep 05, 2018 2:53 pm
Offline
Hello Yael,
Designer shouldn't crash - if it does, thats a bug. I'll take a look. I first thought it could be the changed function names, but then these can be specified in the box config...
Cheers,
Jussi
Top
 Profile
PostPosted: Wed Sep 05, 2018 3:41 pm
Offline
Ok, getting back on this, the problem is that your code is missing the assignment of the header -- in OV all streams must have one. You need to add the following to the part of Process() where you iterate over the inputs,
Code:
      box_in.outputs{1}.header = box_in.inputs{1}.header;
The crash on the other hand was a C++ bug in the Matlab box, I'll fix that in git.
Thanks for the report!
Best,
Jussi
Top
 Profile
PostPosted: Wed Oct 03, 2018 10:19 am
Offline
Thanks Jussi, sorry on the delay, we had many holidays and vacation time :)
I managed to fix the problem by deleting this line from the code:
I don't know why but it works perfectly without it.
The only problem I have now is when assigning new variables to the user data in the box in I can't always call them,
I have no idea why it sometimes works and in others doesn't. for example:
when using variable as counter it works :
box initialize function:
box_in.user_data.nb_matrix_processed =0;
box process function:
box_in.user_data.nb_matrix_processed = box_in.user_data.nb_matrix_processed + 1;
if (box_in.user_data.nb_matrix_processed>=4) && mod((box_in.user_data.nb_matrix_processed-1),3)==0
yet when using it to call a file name such:
selpath =uigetdir;
box_in.user_data.path=selpath;
filename3=sprintf('%s',box_in.user_data.path,'\eegdata.mat');
box_in.user_data.filenamedata=filename3;
box uninitialized function:
d=importdata(box_in.user_data.filenamedata);
if box_in.user_data.count*1536<size(d,1)
k=box_in.user_data.count+1;
k1=num2str(k)
filename1=sprintf('%s',box_in.user_data.path,'\eegdata')
filename2=sprintf('%s',k1,'.mat')
filename=sprintf('%s%s',filename1,filename2)
save(filename,'c')
it doesn't work when simply using: save(box_in.user_data.filenamedata,'c').
another example that isn't working is for:
box_in.user_data.g_electrode=0;
if(box_in.user_data.g_electrode==0)
it gives an error for this line.
is there any logic when using this user data variables? when can I call them and how (is it different than what I've tried so far).
Many thanks,
Yael
Top
 Profile
PostPosted: Wed Oct 03, 2018 12:18 pm
Offline
Hi, the following work just fine for me. Can you try these and if they work, modify them to produce your error?
Code:
function box_out = Initialize(box_in)
        box_in.user_data.bool = false;
        box_in.user_data.number = 777;
        box_in.user_data.string = 'teststring';
        box_in.user_data.counter = 0;
        % Don't forget to pass the modified box as output.
        box_out = box_in;
function box_out = Process(box_in)
        disp('Matlab process function has been called.')
%       disp(box_in.user_data)
        txt = sprintf('Bool %d\n', box_in.user_data.bool); disp(txt);
        txt = sprintf('Int  %d\n', box_in.user_data.number); disp(txt);
        txt = sprintf('String %s\n', box_in.user_data.string); disp(txt);
        txt = sprintf('Counter %d\n', box_in.user_data.counter); disp(txt);
        box_in.user_data.counter = box_in.user_data.counter + 1;
        box_out = box_in;
function box_out = Uninitialize(box_in)
        disp(box_in.user_data);
        box_out = box_in;
ps. I'm not sure your modification is appropriate that you mention in the beginning. Please try this hotfix which should address the crash issue, viewtopic.php?f=13&t=9961&p=15889&hilit=matlab#p15889
Cheers,
Jussi
Top
 Profile
PostPosted: Wed Oct 03, 2018 1:22 pm
Offline
Hi, thanks, now I know what is the problem I am calling another function from the process function. the function is located just bellow in the process function code. I thought that the user data variables are global, do you have any idea how can I call them without doing upload of the file? can I define the user data variables as global?
Thanks,
Yael
Top
 Profile
PostPosted: Thu Oct 04, 2018 6:34 am
Offline
Thanks for all your help, I've figured it out, stupid mistake.
Thanks again,
Yael
Top
 Profile
PostPosted: Thu Oct 04, 2018 8:24 am
Offline
Ok, great. Btw I imagine global variables work just as they usually do in Matlab. And you can of course pass box_in further to some of your own functions.
Cheers,
Jussi
Top
 Profile
PostPosted: Thu Oct 04, 2018 12:40 pm
Offline
Thanks, I did transfer the box_in to the next function and retrieved it, this is how I solved the problem, as I said stupid mistake, that took me a whole day.
Thanks again,
Yael
Top
 Profile
Who is online
Users browsing this forum: No registered users and 3 guests
Search for:
Jump to:
cron
Americanized by Maƫl Soucaze.
