Dear all,
Hello. Now I want your helps with building OpenViBE 2.0.0 on windows
Here's my environment
OS: Windows 10 64 bit
Visual Studio 2013 Community
I followed the instruction on the webpage (Instructions for Building OpenViBE - Windows compilation)
Installed Openvibe files are located in C:\openvibe-src
I launched install_dependencies.cmd and installed jinja2 and finally executed build --vsbuild-all, but several errors occured
and finally it said,
Generating meta project
Parsing C:\openvibe-src\build\sdk\OpenVIBE.sln
C:\openvibe-src\build\designer\Designer.sln does not exist !
C:\openvibe-src\build\extras\OpenVIBE.sln does not exist !
Project [C:\openvibe-src\\build\OpenViBE-Meta.sln] generated
C:\openvibe-src\sdk\unit-test\openvibe-module-fs\uoFilesTestUTF.cpp : warning C4819: The file contains a character that cannot be represented in the current code page (949). Save the file in Unicode format to prevent data loss [C:\openvibe-src\build\sdk\unit-test\openvibe-module-fs\openvibe-module-fs-test-utf.vcxproj]
C:\openvibe-src\sdk\unit-test\openvibe-module-fs\uoFilesTestUTF.cpp(9): error C2001: newline in constant [C:\openvibe-src\build\sdk\unit-test\openvibe-module-fs\openvibe-module-fs-test-utf.vcxproj]
above is the errors mainly appeared.
Below URL: all text output when build --vsbuild-all was executed
https://drive.google.com/open?id=1IhiKn ... 35SBgASfJQ
I don't know what I missed in the instruction.
Thank you.
OpenViBE 2.0.0 build fails on Windows
Re: OpenViBE 2.0.0 build fails on Windows
Hi,
it appears that the community edition of VS doesn't handle asian unicode characters on your system. We haven't really tried VS2013 CE here; many people work with the commercial (pro) edition, or Express.
You could try to address the issue by skipping the compilation of the unit tests. Replace file sdk/unit-test/CMakeLists.txt with an empty file and try to build again.
Let us know if it works. Or if not, please paste the remaining errors here and we'll see what we can do.
Best,
Jussi
Best,
Jussi
Dear Jussi,
Hello. Thank you for your advise.
I just followed your instruction (skipping unit-test) by replacing file sdk/unit-test/CMakeLists.txt with an empty file and trying to build again.
It said that all builds were succeeded, but an error occured during building process.
Result output is attaced in the URL: https://drive.google.com/open?id=1BnC3e ... BZXJY0U5j0
I tested it with the same system (VS 2013 community).
Thank you.
Regards,
Kyungho Won
Code: Select all
Time Elapsed 00:00:03.08
Building designer
Build type is set to: MultiType.
Visual Studio 2017 detection skipped as requested
Visual Studio 2015 detection skipped as requested
Found VS120 tools at "C:\Program Files (x86)\Microsoft Visual Studio 12.0\Common7\Tools\../../VC/vcvarsall.bat" ...
SDK is located at C:\openvibe-src\\dist\sdk
Microsoft (R) Build Engine version 12.0.31101.0
[Microsoft .NET Framework, version 4.0.30319.42000]
Copyright (C) Microsoft Corporation. All rights reserved.
MSBUILD : error MSB1009: Project file does not exist.
Switch: Designer.sln
An error occured during building process
Building extras
No script specified. Default will be used.
Init-env Script to be called: win32-init_env_command.cmd.
Found VS120 tools at "C:\Program Files (x86)\Microsoft Visual Studio 12.0\Common7\Tools\" ...
Designer is located at C:\openvibe-src\\dist\designer
_______________________________________________________________________________
Generating makefiles for Visual Studio 12.
Building to C:\openvibe-src\\build\extras ...
-- Appending compilation flags...
-- Found Debug of sdk at C:/openvibe-src/dist/sdk/Debug
-- Found Release of sdk at C:/openvibe-src/dist/sdk/Release
CMake Error at cmake-modules/FindOVDesigner.cmake:33 (message):
Did not find any valid build of OpenViBE Designer
Call Stack (most recent call first):
CMakeLists.txt:98 (include)
-- Configuring incomplete, errors occurred!
See also "C:/openvibe-src/build/extras/CMakeFiles/CMakeOutput.log".
C:\openvibe-src>build --vsbuild-all > result.txt
Regards,
Kyungho Won
It looks better, but still fails for some reason. Did you try to make a clean build? To get that, either rename or delete both folders 'dist' and 'build' and after that, run again
build.cmd --vsbuild-all
Do you get the same result?
Best,
Jussi
Best,
Jussi
Oh, I forgot to make a clean build.
So I tried to make a clean build this time, and it works even though lots of warnings related to Unicode (C4819)
Can I use the whole function using the build without unit-test?
Great thanks.
Regards,
Kyungho Won
Great thanks.
Regards,
Kyungho Won
I think so. The unit tests are not needed for 'normal' use of openvibe, they just test the codebase and are only executed on demand.
The main thing to check is that designer and acquisition server that appear installed under dist/ seem to be normally functional; just try using them and see if you run into any trouble (for example related to unicode).
Cheers,
Jussi
Cheers,
Jussi
Sorry for late reply.
I tested basic functionals working in /dist/extras/Release.
Tested scenario:
acquisition-server - generic oscillator
designer - acquisiton client, signal display
Great thanks!
Regards,
Kyungho Won.
Tested scenario:
Great thanks!
Regards,
Kyungho Won.
