Hey,
For my small application I decided to use the OSC box to send alpha and beta power to unity. But if I remember correctly you can only send single values via that box, so depending on what data you want it might not be the beat choice. I also have some code for the TCP writer that at least reads thr header correctly , but the reading of the signal matrix has not been finished. I am currently on the mobile phone so I might post it later.
Cheers
Edit: The code I have here was not tested or finished, but it should give an Idea on how to deal with the TCPWriter.
Code:
using UnityEngine;
using System.Collections;
using System;
using System.IO;
using System.Net.Sockets;
using System.Text;
using UnityEngine.UI;
// http://answers.unity3d.com/questions/15422/unity-project-and-3rd-party-apps.html
public class s_TCP : MonoBehaviour
internal Boolean socketReady = false;
TcpClient mySocket;
NetworkStream theStream;
StreamWriter theWriter;
StreamReader theReader;
String Host = "localhost";
public Int32 Port = 5678;
public bool testHeader = true;
public bool testSignal = false;
public bool isString = false;
public int testSampleChannelSize;
public int testSampleCount;
public int testChannelCount;
public double[,] lastMatrix;
public float power;
public RawOpenVibeSignal lastSignal;
Rigidbody2D rb;
public class RawOpenVibeSignal {
public int channels;
public int samples;
public double[,] signalMatrix;
void Start()
setupSocket();
void FixedUpdate()
power = ((float)readSocket());
public void setupSocket()
try
mySocket = new TcpClient(Host, Port);
theStream = mySocket.GetStream();
theWriter = new StreamWriter(theStream);
theReader = new StreamReader(theStream);
socketReady = true;
catch (Exception e)
Debug.Log("Socket error: " + e);
public void writeSocket(string theLine)
if (!socketReady)
return;
String foo = theLine + "\r\n";
theWriter.Write(foo);
theWriter.Flush();
public double readSocket()
if (!socketReady)
return 0; // TODO
if (theStream.DataAvailable)
// read header once
if (testHeader)
readHeader();
if (testSignal)
// raw signal data
// [nSamples x nChannels]
// all channels for one sample are sent in a sequence, then all channels of the next sample
// create a signal object to send it to another
RawOpenVibeSignal newSignal = new RawOpenVibeSignal();
newSignal.samples = testSampleCount;
newSignal.channels = testChannelCount;
double[,] newMatrix = new double[testSampleCount,testChannelCount];
byte[] buffer = new byte[testSampleChannelSize];
theStream.Read(buffer, 0, testSampleChannelSize);
int row = 0;
int col = 0;
for (int i = 0; i < testSampleCount * testChannelCount * (sizeof(double)); i = i + (sizeof(double) * testChannelCount))
for (int j = 0; j < testChannelCount * sizeof(double); j = j + sizeof(double))
byte[] temp = new byte[8];
for(int k = 0; k < 8; k++)
temp[k] = buffer[i + j + k];
if (BitConverter.IsLittleEndian)
// Array.Reverse(temp);
double test = BitConverter.ToDouble(temp, 0);
// TODO TEST THIS
//newMatrix[i / (8 * testChannelCount), j / 8] = test;
newMatrix[row, col] = test;
col++;
row++;
col = 0;
newSignal.signalMatrix = newMatrix;
lastSignal = newSignal;
lastMatrix = newMatrix;
displaySignalText();
return newMatrix[0, 0];
else if (isString) {
Debug.Log(theReader.ReadLine());
return 0;
private void readHeader()
// size of header is 8 * size of unit = 32 byte
int variableSize = sizeof(UInt32);
int variableCount = 8;
int headerSize = variableCount * variableSize;
byte[] buffer = new byte[headerSize];
theStream.Read(buffer, 0, headerSize);
// version number (in network byte order)
// endianness of the stream (in network byte order, 0==unknown, 1==little, 2==big, 3==pdp)
// sampling frequency of the signal,
// number of channels,
// number of samples per chunk and
// three variables of padding
UInt32 version, endiannes, frequency, channels, samples;
byte[] v = new byte[4] { buffer[0], buffer[1], buffer[2], buffer[3] };
byte[] e = new byte[4] { buffer[4], buffer[5], buffer[6], buffer[7] };
byte[] f = new byte[4] { buffer[8], buffer[9], buffer[10], buffer[11] };
byte[] c = new byte[4] { buffer[12], buffer[13], buffer[14], buffer[15] };
byte[] s = new byte[4] { buffer[16], buffer[17], buffer[18], buffer[19] };
Array.Reverse(e);
Array.Reverse(v);
version = BitConverter.ToUInt32(v, 0);
endiannes = BitConverter.ToUInt32(e, 0);
frequency = BitConverter.ToUInt32(f, 0);
channels = BitConverter.ToUInt32(c, 0);
samples = BitConverter.ToUInt32(s, 0);
else
version = 999;
endiannes = 0;
frequency = 0;
channels = 0;
samples = 0;
// Debug.Log("Version: " + version + "\n" + "Endiannes: " + endiannes + "\n" + "sampling frequency of the signal: " + frequency + "\n" + "number of channels: " + channels + "\n" + "number of samples per chunk: " + samples + "\n");
testHeader = false;
testSampleCount = buffer[16];
testChannelCount = buffer[12];
testSampleChannelSize = buffer[12] * buffer[16] * sizeof(double);
testSignal = true;
rb = GetComponent<Rigidbody2D>();
public void closeSocket()
if (!socketReady)
return;
theWriter.Close();
theReader.Close();
mySocket.Close();
void displaySignalText() {
RawOpenVibeSignal s = lastSignal;
StringBuilder sb = new StringBuilder();
for (int i = 0; i < lastSignal.samples; i++) {
sb.AppendLine("Sample" + i + "\t");
for (int j = 0; j < lastSignal.channels; j++)
try
sb.AppendLine("Channel" + j).Append(lastSignal.signalMatrix[i, j]);
catch {
Debug.Log("i:" + i + "-j:" + j);
// Debug.Log(sb.ToString());
void OnApplicationQuit()
closeSocket();
} // end class s_TCP
