First of all: This software is amazing. Thank you very much!
At the moment I am struggling to design a neurofeeback protocol that does not feed back a visual stimulus but a sound signal.
I would like to take the power of a band (alpha or theta) and feed it back as a tone or sound that changes volume.
Basically, that's the BCI example 'Neurofeedback' but not with a plot or a color but a sound.
So far I used the 'sign change detector' box and the 'sound player'. I now have a lower and a higher pitched sound depending on whether the power of a band is above or below a given threshold. However, I would like to have more than two sounds... and continuous change not a few steps...
I would appreciate any hint!
![Smile :)](./images/smilies/icon_smile.gif)
Thank you
Clemens
