Designer doesn`t start.
APAA
Post by APAA »
Hello!
I'm new to this forum and EEG. I downloaded openvibe-1.3.0-setup.exe. v1.3.0 and installed. I run openvibe-designer.cmd it will stop working. OS is windows7. Please help me :cry:
APAA
Makosa
Re: Designer doesn`t start.
Post by Makosa »
First, make sure you are using the latest official version of OpenViBE, and not either an old version or a third party version.
A good place to start learning about the platform is to read the existing documentation. Several documents and tutorials are dedicated to explaining the use of the platform and its associated tools.
_______________
Makosa, Abingdon
siavash82ir
Post by siavash82ir »
طراحی سایت سئوی سایت طراحی سایت فروشگاهی ثبت دامنه میزبانی وب
Hello
I have this problem on windows OS 10
Can anyone guide me?
You have the last version of OpenViBE ? You build your own OpenViBE ? When you launch OpenViBE he say what ?
