I have an Ubuntu 16.04 installation that I used to host openvibe and run it without problems, until recently (probably after updates to the base system?), openvibe-designer stop working and results the followig error:
Anyone experiencing the same problem? I have also downloaded recent version from github and compiled it but without any luck. The other scripts run without problem though../openvibe-designer.sh: line 57: 3155 Aborted (core dumped)
The system is using:
kernel 4.4.0-38-generic
Ubuntu 16.04LTS
Thanks in advance
