receive stimulations after restart of Designer
About the GUI application to design signal processing pipelines
Post Reply
barten6
Post by barten6 »
Hi,
I Need to receive Keyboard stimulations also after stopping and resuming designer-Operation.
Certainly, this can be done by clicking on the kbd-stim Window to activate it.
To be able to automatize Stimulation-controlled designer-Operation, however,
1. kbd-stim Windows must be the active window after start of designer-Operation (> Icon)
2. kbd-stim must be reactivated after clicking around in the designer (eg for changing Parameters in a signal Display box).
How can this be achieved best in a way not requiring Manual interaction with the Screen?
would appreciate your advice!
Best regards
P.B.
nfoy
Re: receive stimulations after restart of Designer
Post by nfoy »
Hi,
I'm afraid there is no other solution that clicking on the kbd-stim window to receive keyboard inputs in the running scenario. This is due to how the keyboard stims were originally designed.
Best regards
Post Reply
