Hi All
Need some help from the experts as clearly I am not one...
I have two small questions: 1. I am trying to do a simple calculation to determine the F4 ( sensor signal ) - F3 ( sensor signal ) = ? ( This then needs to be used externally via a VRPN in a web browsers to indicate visually the amount ). I was wondering if anyone could give me some guidance on achieving this ( OpenVIBE designer code below )
2. After creating the Designer XML and everything working the way it should. Is there a way of running the Acquisition Client / Designer file / VRPN all with a single file or package?
PS: Any advice would be greatly appreciated.
Code:
<OpenViBE-Scenario>
<Boxes>
<Box>
<Identifier>(0x000002df, 0x0000333b)</Identifier>
<Name>Acquisition client</Name>
<AlgorithmClassIdentifier>(0x35d225cb, 0x3e6e3a5f)</AlgorithmClassIdentifier>
<Outputs>
<Output>
<TypeIdentifier>(0x403488e7, 0x565d70b6)</TypeIdentifier>
<Name>Experiment information</Name>
</Output>
<Output>
<TypeIdentifier>(0x5ba36127, 0x195feae1)</TypeIdentifier>
<Name>Signal stream</Name>
</Output>
<Output>
<TypeIdentifier>(0x6f752dd0, 0x082a321e)</TypeIdentifier>
<Name>Stimulations</Name>
</Output>
<Output>
<TypeIdentifier>(0x013df452, 0xa3a8879a)</TypeIdentifier>
<Name>Channel localisation</Name>
</Output>
<Output>
<TypeIdentifier>(0x6ab26b81, 0x0f8c02f3)</TypeIdentifier>
<Name>Channel units</Name>
</Output>
</Outputs>
<Settings>
<Setting>
<TypeIdentifier>(0x79a9edeb, 0x245d83fc)</TypeIdentifier>
<Name>Acquisition server hostname</Name>
<DefaultValue>${AcquisitionServer_HostName}</DefaultValue>
<Value>${AcquisitionServer_HostName}</Value>
<Modifiability>false</Modifiability>
</Setting>
<Setting>
<TypeIdentifier>(0x007deef9, 0x2f3e95c6)</TypeIdentifier>
<Name>Acquisition server port</Name>
<DefaultValue>1024</DefaultValue>
<Value>1024</Value>
</Setting>
</Settings>
<Attributes>
<Attribute>
<Identifier>(0x1fa7a38f, 0x54edbe0b)</Identifier>
<Value>80.000000</Value>
</Attribute>
<Attribute>
<Identifier>(0x1fa963f5, 0x1a638cd4)</Identifier>
<Value>23</Value>
</Attribute>
<Attribute>
<Identifier>(0x207c9054, 0x3c841b63)</Identifier>
<Value>480.000000</Value>
</Attribute>
<Attribute>
<Identifier>(0x4e7b798a, 0x183beafb)</Identifier>
<Value>(0x0d4656c0, 0xc95b1fa8)</Value>
</Attribute>
<Attribute>
<Identifier>(0xad100179, 0xa3c984ab)</Identifier>
<Value>106</Value>
</Attribute>
<Attribute>
<Identifier>(0xc46b3d00, 0x3e0454e1)</Identifier>
<Value>(0x00000000, 0x000a4dbe)</Value>
</Attribute>
<Attribute>
<Identifier>(0xc73e83ec, 0xf855c5bc)</Identifier>
<Value>false</Value>
</Attribute>
<Attribute>
<Identifier>(0xc80ce8af, 0xf699f813)</Identifier>
<Value>5</Value>
</Attribute>
<Attribute>
<Identifier>(0xce18836a, 0x9c0eb403)</Identifier>
<Value>2</Value>
</Attribute>
</Attributes>
</Box>
<Box>
<Identifier>(0x0000141b, 0x000038c6)</Identifier>
<Name>Signal display</Name>
<AlgorithmClassIdentifier>(0x0055be5f, 0x087bdd12)</AlgorithmClassIdentifier>
<Inputs>
<Input>
<Name>Data</Name>
</Input>
<Input>
</Input>
<Input>
<Name>Channel Units</Name>
</Input>
</Inputs>
<Settings>
<Setting>
<TypeIdentifier>(0x5de046a6, 0x086340aa)</TypeIdentifier>
<Name>Display Mode</Name>
<DefaultValue>Scan</DefaultValue>
<Value>Scan</Value>
</Setting>
<Setting>
<TypeIdentifier>(0x33a30739, 0x00d5299b)</TypeIdentifier>
<Name>Auto vertical scale</Name>
<DefaultValue>Per channel</DefaultValue>
<Value>Per channel</Value>
</Setting>
<Setting>
<TypeIdentifier>(0x512a166f, 0x5c3ef83f)</TypeIdentifier>
<Name>Scale refresh interval (secs)</Name>
<DefaultValue>5</DefaultValue>
<Value>5</Value>
</Setting>
<Setting>
<Name>Vertical Scale</Name>
<DefaultValue>100</DefaultValue>
<Value>100</Value>
</Setting>
<Setting>
<Name>Vertical Offset</Name>
<DefaultValue>0</DefaultValue>
<Value>0</Value>
</Setting>
<Setting>
<Name>Time Scale</Name>
<DefaultValue>10</DefaultValue>
<Value>10</Value>
</Setting>
<Setting>
<TypeIdentifier>(0x2cdb2f0b, 0x12f231ea)</TypeIdentifier>
<Name>Bottom ruler</Name>
<DefaultValue>true</DefaultValue>
<Value>true</Value>
</Setting>
<Setting>
<Name>Left ruler</Name>
<DefaultValue>false</DefaultValue>
</Setting>
<Setting>
<Name>Multiview</Name>
</Setting>
</Settings>
<Attributes>
<Attribute>
<Value>320.000000</Value>
</Attribute>
<Attribute>
<Value>34</Value>
</Attribute>
<Attribute>
<Value>272.000000</Value>
</Attribute>
<Attribute>
<Value>(0x92c056a7, 0x2dc71aff)</Value>
</Attribute>
<Attribute>
<Identifier>(0x527ad68d, 0x16d746a0)</Identifier>
<Value></Value>
</Attribute>
<Attribute>
<Value>87</Value>
</Attribute>
<Attribute>
<Value>(0x00000000, 0x00101cdf)</Value>
</Attribute>
<Attribute>
</Attribute>
<Attribute>
<Value>9</Value>
</Attribute>
<Attribute>
<Identifier>(0xcfad85b0, 0x7c6d841c)</Identifier>
<Value>3</Value>
</Attribute>
</Attributes>
</Box>
<Box>
<Identifier>(0x00002376, 0x00000c86)</Identifier>
<Name>Analog VRPN Server</Name>
<AlgorithmClassIdentifier>(0x0ddc3a7e, 0x6f6e6401)</AlgorithmClassIdentifier>
<Inputs>
<Input>
<TypeIdentifier>(0x544a003e, 0x6dcba5f6)</TypeIdentifier>
<Name>Input 1</Name>
</Input>
</Inputs>
<Settings>
<Setting>
<Name>Peripheral name</Name>
<DefaultValue>openvibe-vrpn</DefaultValue>
<Value>openvibe_vrpn_analog</Value>
</Setting>
</Settings>
<Attributes>
<Attribute>
<Value>352.000000</Value>
</Attribute>
<Attribute>
<Value>34</Value>
</Attribute>
<Attribute>
<Value>464.000000</Value>
</Attribute>
<Attribute>
<Value>(0x2f4c9e00, 0x5dc619e4)</Value>
</Attribute>
<Attribute>
<Value>122</Value>
</Attribute>
<Attribute>
<Value>(0x00000000, 0x006eeca6)</Value>
</Attribute>
<Attribute>
<Value>1</Value>
</Attribute>
<Attribute>
<Value>1</Value>
</Attribute>
<Attribute>
<Identifier>(0xfba64161, 0x65304e21)</Identifier>
<Value></Value>
</Attribute>
</Attributes>
</Box>
<Box>
<Identifier>(0x000034ab, 0x000035c2)</Identifier>
<Inputs>
<Input>
<Name>Data</Name>
</Input>
<Input>
</Input>
<Input>
</Input>
</Inputs>
<Settings>
<Setting>
<Value>Scan</Value>
</Setting>
<Setting>
</Setting>
<Setting>
<Value>5</Value>
</Setting>
<Setting>
<Value>100</Value>
</Setting>
<Setting>
<Value>0</Value>
</Setting>
<Setting>
<Value>10</Value>
</Setting>
<Setting>
<Value>true</Value>
</Setting>
<Setting>
</Setting>
<Setting>
</Setting>
</Settings>
<Attributes>
<Attribute>
</Attribute>
<Attribute>
<Value>34</Value>
</Attribute>
<Attribute>
<Value>624.000000</Value>
</Attribute>
<Attribute>
</Attribute>
<Attribute>
<Value></Value>
</Attribute>
<Attribute>
<Value>87</Value>
</Attribute>
<Attribute>
<Value>(0x00000000, 0x000ac324)</Value>
</Attribute>
<Attribute>
</Attribute>
<Attribute>
<Value>9</Value>
</Attribute>
<Attribute>
<Value>3</Value>
</Attribute>
</Attributes>
</Box>
<Box>
<Identifier>(0x00004f02, 0x000066e4)</Identifier>
<Name>F4</Name>
<AlgorithmClassIdentifier>(0x361722e8, 0x311574e8)</AlgorithmClassIdentifier>
<Inputs>
<Input>
<Name>Input signal</Name>
</Input>
</Inputs>
<Outputs>
<Output>
<Name>Output signal</Name>
</Output>
</Outputs>
<Settings>
<Setting>
<Name>Channel List</Name>
<DefaultValue>:</DefaultValue>
<Value>F4</Value>
</Setting>
<Setting>
<TypeIdentifier>(0x3bcf9e67, 0x0c23994d)</TypeIdentifier>
<Name>Action</Name>
<DefaultValue>Select</DefaultValue>
<Value>Select</Value>
</Setting>
<Setting>
<TypeIdentifier>(0x666f25e9, 0x3e5738d6)</TypeIdentifier>
<Name>Channel Matching Method</Name>
<DefaultValue>Smart</DefaultValue>
<Value>Smart</Value>
</Setting>
</Settings>
<Attributes>
<Attribute>
<Value>176.000000</Value>
</Attribute>
<Attribute>
<Value>45</Value>
</Attribute>
<Attribute>
<Value>368.000000</Value>
</Attribute>
<Attribute>
<Identifier>(0x30a4e5c9, 0x83502953)</Identifier>
<Value></Value>
</Attribute>
<Attribute>
<Value>(0x277826e1, 0xa30a3bd0)</Value>
</Attribute>
<Attribute>
<Value></Value>
</Attribute>
<Attribute>
<Value>80</Value>
</Attribute>
<Attribute>
<Value>(0x00000000, 0x000e56ec)</Value>
</Attribute>
<Attribute>
</Attribute>
<Attribute>
<Value>1</Value>
</Attribute>
<Attribute>
<Value>3</Value>
</Attribute>
<Attribute>
<Value>1</Value>
</Attribute>
</Attributes>
</Box>
<Box>
<Identifier>(0x00006287, 0x00003a90)</Identifier>
<Name>F3</Name>
<Inputs>
<Input>
</Input>
</Inputs>
<Outputs>
<Output>
</Output>
</Outputs>
<Settings>
<Setting>
<Value>F3</Value>
</Setting>
<Setting>
<Name>Action</Name>
</Setting>
<Setting>
</Setting>
</Settings>
<Attributes>
<Attribute>
<Value>160.000000</Value>
</Attribute>
<Attribute>
<Value>45</Value>
</Attribute>
<Attribute>
<Value>608.000000</Value>
</Attribute>
<Attribute>
<Value></Value>
</Attribute>
<Attribute>
</Attribute>
<Attribute>
<Value></Value>
</Attribute>
<Attribute>
<Value>80</Value>
</Attribute>
<Attribute>
<Value>(0x00000000, 0x0028b9a3)</Value>
</Attribute>
<Attribute>
</Attribute>
<Attribute>
<Value>1</Value>
</Attribute>
<Attribute>
<Value>3</Value>
</Attribute>
<Attribute>
<Value>1</Value>
</Attribute>
</Attributes>
</Box>
<Box>
<Identifier>(0x000068dd, 0x0000471e)</Identifier>
<Name>Simple DSP</Name>
<AlgorithmClassIdentifier>(0x00e26fa1, 0x1dbab1b2)</AlgorithmClassIdentifier>
<Inputs>
<Input>
<Name>B</Name>
</Input>
<Input>
<Name>A</Name>
</Input>
</Inputs>
<Outputs>
<Output>
<Name>Output</Name>
</Output>
</Outputs>
<Settings>
<Setting>
<Name>Equation</Name>
<DefaultValue>x</DefaultValue>
<Value>B - A</Value>
</Setting>
</Settings>
<Attributes>
<Attribute>
<Value>273.000000</Value>
</Attribute>
<Attribute>
<Value>34</Value>
</Attribute>
<Attribute>
</Attribute>
<Attribute>
<Value></Value>
</Attribute>
<Attribute>
<Value>(0x21889dc4, 0x1126497e)</Value>
</Attribute>
<Attribute>
<Value></Value>
</Attribute>
<Attribute>
<Value>73</Value>
</Attribute>
<Attribute>
<Value>(0x00000000, 0x000e27ec)</Value>
</Attribute>
<Attribute>
</Attribute>
<Attribute>
<Value>1</Value>
</Attribute>
<Attribute>
<Value>1</Value>
</Attribute>
<Attribute>
<Value>1</Value>
</Attribute>
<Attribute>
<Value></Value>
</Attribute>
</Attributes>
</Box>
</Boxes>
<Links>
<Link>
<Identifier>(0x000009a7, 0x000056aa)</Identifier>
<Source>
<BoxIdentifier>(0x00006287, 0x00003a90)</BoxIdentifier>
<BoxOutputIndex>0</BoxOutputIndex>
</Source>
<Target>
<BoxIdentifier>(0x000034ab, 0x000035c2)</BoxIdentifier>
<BoxInputIndex>0</BoxInputIndex>
</Target>
<Attributes>
<Attribute>
<Identifier>(0x1b32c44c, 0x1905e0e9)</Identifier>
<Value>189</Value>
</Attribute>
<Attribute>
<Identifier>(0x358ae8b5, 0x0f8bacd1)</Identifier>
<Value>608</Value>
</Attribute>
<Attribute>
<Identifier>(0x3f0a3b27, 0x570913d2)</Identifier>
<Value>298</Value>
</Attribute>
<Attribute>
<Identifier>(0x6267b5c5, 0x676e3e42)</Identifier>
<Value>609</Value>
</Attribute>
</Attributes>
</Link>
<Link>
<Identifier>(0x00001873, 0x00001804)</Identifier>
<Source>
<BoxIdentifier>(0x00004f02, 0x000066e4)</BoxIdentifier>
</Source>
<Target>
<BoxIdentifier>(0x0000141b, 0x000038c6)</BoxIdentifier>
</Target>
<Attributes>
<Attribute>
<Value>205</Value>
</Attribute>
<Attribute>
<Value>368</Value>
</Attribute>
<Attribute>
<Value>298</Value>
</Attribute>
<Attribute>
<Value>257</Value>
</Attribute>
</Attributes>
</Link>
<Link>
<Identifier>(0x00001dc8, 0x00003cd2)</Identifier>
<Source>
<BoxIdentifier>(0x000068dd, 0x0000471e)</BoxIdentifier>
</Source>
<Target>
<BoxIdentifier>(0x00002376, 0x00000c86)</BoxIdentifier>
</Target>
<Attributes>
<Attribute>
<Value>296</Value>
</Attribute>
<Attribute>
<Value>464</Value>
</Attribute>
<Attribute>
<Value>330</Value>
</Attribute>
<Attribute>
<Value>464</Value>
</Attribute>
</Attributes>
</Link>
<Link>
<Identifier>(0x0000269f, 0x00003c9b)</Identifier>
<Source>
</Source>
<Target>
<BoxInputIndex>1</BoxInputIndex>
</Target>
<Attributes>
<Attribute>
<Value>189</Value>
</Attribute>
<Attribute>
<Value>608</Value>
</Attribute>
<Attribute>
<Value>251</Value>
</Attribute>
<Attribute>
<Value>471</Value>
</Attribute>
</Attributes>
</Link>
<Link>
<Identifier>(0x00002726, 0x00002922)</Identifier>
<Source>
<BoxIdentifier>(0x000002df, 0x0000333b)</BoxIdentifier>
<BoxOutputIndex>1</BoxOutputIndex>
</Source>
<Target>
</Target>
<Attributes>
<Attribute>
<Value>98</Value>
</Attribute>
<Attribute>
<Value>465</Value>
</Attribute>
<Attribute>
<Value>133</Value>
</Attribute>
<Attribute>
<Value>608</Value>
</Attribute>
</Attributes>
</Link>
<Link>
<Identifier>(0x0000383a, 0x00007b60)</Identifier>
<Source>
</Source>
<Target>
</Target>
<Attributes>
<Attribute>
<Value>205</Value>
</Attribute>
<Attribute>
<Value>368</Value>
</Attribute>
<Attribute>
<Value>251</Value>
</Attribute>
<Attribute>
<Value>456</Value>
</Attribute>
</Attributes>
</Link>
<Link>
<Identifier>(0x00006a5b, 0x00001765)</Identifier>
<Source>
</Source>
<Target>
</Target>
<Attributes>
<Attribute>
<Value>98</Value>
</Attribute>
<Attribute>
<Value>465</Value>
</Attribute>
<Attribute>
<Value>149</Value>
</Attribute>
<Attribute>
<Value>368</Value>
</Attribute>
</Attributes>
</Link>
</Links>
<MessageLinks></MessageLinks>
<Comments></Comments>
<VisualisationTree>
<VisualisationWidget>
<Identifier>(0x000019dc, 0x00004429)</Identifier>
<Type>3</Type>
<ParentIdentifier>(0xffffffff, 0xffffffff)</ParentIdentifier>
<NumChildren>0</NumChildren>
</VisualisationWidget>
<Identifier>(0x00003dfb, 0x00001ceb)</Identifier>
<Type>3</Type>
<Identifier>(0x00005fa1, 0x00006ba8)</Identifier>
<Name>Default window</Name>
<Type>1</Type>
<BoxIdentifier>(0xffffffff, 0xffffffff)</BoxIdentifier>
<NumChildren>1</NumChildren>
<Attributes>
<Attribute>
<Identifier>(0x4c90d4ad, 0x7a2554ec)</Identifier>
<Value>320</Value>
</Attribute>
<Attribute>
<Identifier>(0x7b814cca, 0x271df6dd)</Identifier>
<Value>475</Value>
</Attribute>
</Attributes>
<Identifier>(0x0000615b, 0x0000099e)</Identifier>
<Name>Default tab</Name>
<Type>2</Type>
<ParentIdentifier>(0x00005fa1, 0x00006ba8)</ParentIdentifier>
<Index>0</Index>
<Identifier>(0x000030ab, 0x00006832)</Identifier>
<Name>Empty</Name>
<Type>0</Type>
<ParentIdentifier>(0x0000615b, 0x0000099e)</ParentIdentifier>
<Index>0</Index>
</VisualisationTree>
</OpenViBE-Scenario>
