using single input to python tool box to pass all channels
HA3
Post by HA3 »
I have make the following editing on the averaging signal example in python tutorial, and I apply it on 3 channels with one input to the python scripting toolbox and one output , but it's always gives me that there is one input and one output, I conclude that we have to do channel localization and pass each channel to an input of the python toolbox, for example if i have 3 channels, then I should have 3 input signal to that toolbox and the same thing applies to the output of the toolbox, is that necessary?
the expected output of my code is to average each channel.
# we use numpy to compute the mean of an array of values
import numpy
 # let's define a new box class that inherits from OVBox
class MyOVBox(OVBox):
    def __init__(self):
    	OVBox.__init__(self)
    # we add a new member to save the signal header information we will receive
    	self.signalHeader = None
    # The process method will be called by openvibe on every clock tick
    def process(self):
       # we iterate over all the input chunks in the input buffer
      x = len(self.input)
      print ("the size is ", x)
      for i in range(len(self.input)):
       for chunkIndex in range( len(self.input[i]) ):
          # if it's a header we save it and send the output header (same as input, except it has only one channel named 'Mean'
          if(type(self.input[i][chunkIndex]) == OVSignalHeader):
             self.signalHeader = self.input[i].pop()
             outputHeader = OVSignalHeader(
             self.signalHeader.startTime,
             self.signalHeader.endTime,
             [1, self.signalHeader.dimensionSizes[1]],
             ['Mean']+self.signalHeader.dimensionSizes[1]*[''],
             self.signalHeader.samplingRate)
             self.output[i].append(outputHeader)
          # if it's a buffer we pop it and put it in a numpy array at the right dimensions
          # We compute the mean and add the buffer in the box output buffer
          elif(type(self.input[i][chunkIndex]) == OVSignalBuffer):
             chunk = self.input[i].pop()
             numpyBuffer = numpy.array(chunk).reshape(tuple(self.signalHeader.dimensionSizes))
             numpyBuffer = numpyBuffer.mean(axis=0)
             chunk = OVSignalBuffer(chunk.startTime, chunk.endTime, numpyBuffer.tolist())
             self.output[i].append(chunk)
          # if it's a end-of-stream we just forward that information to the output
          elif(type(self.input[i][chunkIndex]) == OVSignalEnd):
             self.output[i].append(self.input[i].pop())
 # Finally, we notify openvibe that the box instance 'box' is now an instance of MyOVBox.
 # Don't forget that step !!
box = MyOVBox()
the output for the
statement always gives me one , and the oscillator is generate 3 channels !,and I expect to have 3 element (or channels) in the
self.input
not one!
this my scenario and the configuration of sinus oscillator which is generate 3 channels
My operating system is ubuntu 14.04 , using openViBE1.0.0
gserrier
Re: using single input to python tool box to pass all channe
Post by gserrier »
You are confusing stream and stream structure.
You box have only one input, so self.input is size 1. For example, if the signal display was a python box, self.input would be equal to 3.
The channel is not a characteristic of the box, but of the stream. As you are using the signal type stream, the stream will have a fix structure (see http://openvibe.inria.fr/stream-structures/). It will be composed of a 2-dimensional matrix of size [N x M] with N the amount of channel, and M the amount of samples by channel.
Guillaume
