using single input to python tool box to pass all channels
Posted: Fri Jun 05, 2015 3:19 pm
I have make the following editing on the averaging signal example in python tutorial, and I apply it on 3 channels with one input to the python scripting toolbox and one output , but it's always gives me that there is one input and one output, I conclude that we have to do channel localization and pass each channel to an input of the python toolbox, for example if i have 3 channels, then I should have 3 input signal to that toolbox and the same thing applies to the output of the toolbox, is that necessary?
the expected output of my code is to average each channel.
the output for the statement always gives me one , and the oscillator is generate 3 channels !,and I expect to have 3 element (or channels) in the not one!
this my scenario and the configuration of sinus oscillator which is generate 3 channels My operating system is ubuntu 14.04 , using openViBE1.0.0
Code: Select all
# we use numpy to compute the mean of an array of values
import numpy
# let's define a new box class that inherits from OVBox
class MyOVBox(OVBox):
def __init__(self):
OVBox.__init__(self)
# we add a new member to save the signal header information we will receive
self.signalHeader = None
# The process method will be called by openvibe on every clock tick
def process(self):
# we iterate over all the input chunks in the input buffer
x = len(self.input)
print ("the size is ", x)
for i in range(len(self.input)):
for chunkIndex in range( len(self.input[i]) ):
# if it's a header we save it and send the output header (same as input, except it has only one channel named 'Mean'
if(type(self.input[i][chunkIndex]) == OVSignalHeader):
self.signalHeader = self.input[i].pop()
outputHeader = OVSignalHeader(
self.signalHeader.startTime,
self.signalHeader.endTime,
[1, self.signalHeader.dimensionSizes[1]],
['Mean']+self.signalHeader.dimensionSizes[1]*[''],
self.signalHeader.samplingRate)
self.output[i].append(outputHeader)
# if it's a buffer we pop it and put it in a numpy array at the right dimensions
# We compute the mean and add the buffer in the box output buffer
elif(type(self.input[i][chunkIndex]) == OVSignalBuffer):
chunk = self.input[i].pop()
numpyBuffer = numpy.array(chunk).reshape(tuple(self.signalHeader.dimensionSizes))
numpyBuffer = numpyBuffer.mean(axis=0)
chunk = OVSignalBuffer(chunk.startTime, chunk.endTime, numpyBuffer.tolist())
self.output[i].append(chunk)
# if it's a end-of-stream we just forward that information to the output
elif(type(self.input[i][chunkIndex]) == OVSignalEnd):
self.output[i].append(self.input[i].pop())
# Finally, we notify openvibe that the box instance 'box' is now an instance of MyOVBox.
# Don't forget that step !!
box = MyOVBox()
Code: Select all
Code: Select all
self.input
