Hi, I have read the tutorials about the Python script box ,but I have one question:how to set the type of output into 'stimulation'.Because there are only 'spectrum' ,'streamed matrix'
and 'signal' in the modify outputs type. If i want to set input/output as type of 'stimulation',what can i do? Thank you fo your help!
some question about Python script
Re: some question about Python script
this looks like a bug we've introduced in 1.0. Its been fixed in the git branch 'release-1.0.0-bugfixes'. If you can get that and recompile it yourself, you're good to go. Otherwise you'll have to wait for us to release a bugfix version (could be next week).
hi,
could you tell me how i can access the 'release-1.0.0-bugfixes'?
After following the instructions fetching the source code ( http://openvibe.inria.fr/repo-instructions ) , do
git checkout release-1.0.0-bugfixes
