Reading Biosemi BDF file using OpenViBE!
mehdiordi
Post by mehdiordi »
Hi OpenViBEers,
I got a question regarding "File reading and writing" in the designer. I am using Biosemi EEG setup for my experiments, and for this reason I need to adjust the openViBE designer to read "BDF" file. But apparently it does not support this format. Information that I got from the forum was in http://openvibe.inria.fr/biosemi-activetwo-driver/
...where the Biosemi Driver has been introduced. But i could not get how to read the BDF file. Any hint is greatly appreciate. Thanks...
Re: Reading Biosemi BDF file using OpenViBE!
Hello Mehdiordi,
as far as I know, this file format is not currently supported. If anybody is interested in contributing a BDF read or write box, we're perfectly happy to consider integrating it to OpenViBE. Currently the core team does not have allocation or plans to implement it ourselves.
